Eleanor's HPDE Track Car...
Old Oct 21, 2007 | 05:35 PM
EleanoR's Avatar
Default Eleanor's HPDE Track Car...
Hey guys,
I've been on honda-tech for years now and a lot of you have helped me out in making decisions on building my hatch, and actually working on it as well so I figured I'd finally post some pictures up of this thing. Some of you may know I had my new engine built by King Motorsports back in the spring. Now, currently this car is strictly an HPDE car as I let my friend 96 SOHC VTEC drive the car as well. Next season I'm considering giving TTA a shot and seeing how that goes as well as doing the regular HPDE's. Down the road I may get into racing but right now I'm not interested.
Anyhow, on to the car.
1993 Honda Civic DX Hatchback: 2,000 lbs dry WITH Cage
Engine & Tranny
Bottom End:
-B18C (GSR) Block
-Golden Eagle Sleeves
-Carillo Rods
-Wiseco 2cc Pistons
-OEM Bearings, Pumps, Gaskets (Cometic head gasket)
-Balanced/Blueprinted
-King Motorsports Super-finishing and Anti-Friction Treatment
-Moroso 20910 Pan
Top End:
-King Stage IV Head Work
-Supertech Valvesprings/Retainers
-Skunk Pro2+ Cams
-Skunk Pro Series Manifold w/ King Coolant Bypass
• AEM Cold Air Intake
• Rage Big Tube 2.0L Header
• Megan Racing Adjustable Cam Gears
• B&M Fuel Pressure Regulator Gauge
• AEM Fuel Pressure Regulator
• Endyn Oil Catch Can
• Microtech Standalone ECU
• Exedy Organic Clutch
• Exedy Lightweight Flywheel
• Innovative Engine Mounts
• Full 2.5in Race Exhaust by Magnflow W/ Turndown
• NGK Spark Plug Wires
• Hondata Intake Manifold Gasket
• Setrab 24 Row Oil Cooler Ducted
• Greddy Oil Filter Relocation Kit
• Bored ITR Throttle Body 64.5 Tapered to 70
• Fluidyne Full Length Radiator
• FAL SlimLine Fan
• USDM 4th & 5th Gear
• Walbro Fuel Pump
• RC 440 Injectors
• Energy Suspension Shifter Bushings
Suspension
• Full Type R Front And Rear With 5 Lug Conversion
• Pic Performance R3 Suspension
• A-Spec Racing Subframe Reinforcement
• ASR 32mm Adjustable Rear Swaybar
• Type R Front Swaybar
• Neuspeed Front Strut Bar
• Cornerweighted
• Skunk2 Front Camber Kit
• Omnipower Rear Camber Kit
• ARP Wheel Studs
• Mugen Rear Trailing Arm Bushings
Brakes
• Tilton Adjustable Rear Brake Prop Valve
• ITR Brakes Front/Rear
• Stoptech Slotted Rotors (Front Only)
• Integra RS Brake Booster
• Integra RS Brake Master Cylinder
• Cobalt XR-2 Front Brake Pads
• Autozone Rear Brake Pads
• Stoptech Stainless Steel Brake Lines
• ATE Superblue Brake Fluid
• Removed All Dust Shields
(Next season brake ducting coming)
Interior
• MazWorx Custom 6 Point Cage w/ Nascar Door Bars
• Automater Oil Pressure Gauge
• Autometer Oil Temperature Gauge
• Autometer Water Temperature Gauge
• Autometer Fuel Level Gauge
• Autometer Tachometer
• Sparco Lap 5 Steering Wheel
• Sparco Quick Disconnect
• Proform Adjustable Shift Light
• Momo Cup GT Passenger Seat
• Racetech Driver Seat
• Genuine Type R shift ****
• Fastline Shifter
• Sparco Carbon Fiber Pedals
• Summit Battery Relocation Kit
• Longacre Igntion & Pushbutton Start
• SPA Digital Speedometer
• Buddy Club Battery
• IOport Camera Mount
• Sparco Dead Pedal
• G-force 5 Point Harness
• Battery Kill Switch
• Sparco Hood Pins
• HotLap In Car Timer System
• Mugen Tow Hook (Front)
Removed Items
• Car Is Fully Gutted
• No AC/PS/Heat
• Removed Drivers and Passenger Side Windows
• Removed Rear Wiper
• Removed Front Bumper Brace
• Removed Sound Deadening
• Removed Front Wiper System
• Interior Doors Cut Out
• Removed Engine Torque Mounts
• FAL Lexan Windows (Back 3)
• Megan Racing Duckbill Rear Spoiler
• Road Race Gear Front Air Dam & Splitter
• Import Precision Carbon Fiber Hood
I have two sets of wheels -
Volk Racing CE28 Forged 15x7 Wrapped in GoodYear Eagle RS DOT Radial Slick 205/50/15 (Main wheels)
•Rota Slipstream 15x7 Wrapped in GoodYear Eagle RS DOT Radial Slick 205/50/15 (Backup)
The car was corner weighted without the passenger seat and 1/4 tank of fuel at 2010 lbs. The car made 225whp for 5 consistent runs. Now that the motor is more broken in I'm hoping for 230whp next time at the dyno.
Here are some pics. Originally this car was blue and looked like crap so when I blew the first motor I had it repainted Championship White. I also posted some videos under the last picture.
96 SOHC VTEC heading out.
And here a few videos of the car in action.
The first video is 96 SOHC VTEC driving at Homestead.
http://videos.streetfire.net/v...4.htm
This video is of me drivng at Sebring.
http://videos.streetfire.net/v...2.htm
more videos:
http://videos.streetfire.net/v...3.htm
http://videos.streetfire.net/v...6.htm
Modified by EleanoR at 8:20 PM 10/22/2007
Modified by EleanoR at 7:29 PM 12/19/2007
Old Oct 21, 2007 | 05:37 PM
777's Avatar
777
Default Re: Eleanor's HPDE Track Car... (EleanoR)
Sick...
Old Oct 21, 2007 | 05:42 PM
Slopoke's Avatar
Love it!
Old Oct 21, 2007 | 05:43 PM
b6t's Avatar
b6t
done the way it should be done for a well sorted out track car.
Old Oct 21, 2007 | 05:53 PM
Markland Photo's Avatar
looks like it does business
Old Oct 21, 2007 | 06:02 PM
Drew17th's Avatar
really clean and nice car!!!
Old Oct 21, 2007 | 06:15 PM
chads's Avatar
Default Re: Eleanor's HPDE Track Car... (Drew17th)
amazing! good work
Old Oct 21, 2007 | 06:25 PM
sp00nek9's Avatar
Default Re: Eleanor's HPDE Track Car... (chads)
looks good bro
Old Oct 21, 2007 | 06:29 PM
1200 Hobos's Avatar
Default Re: Eleanor's HPDE Track Car... (sp00nek9)
Wow, I'm in for this. Just skimmed through it for now but it looks like a hell of a project. That block set up is insane.
What did you use to spray the floor of your interior?
Is that the same paint as say the exterior and everythign else?
What color is it?
One thing. Aren't you supposed to wrap the header with that tape as opposed to the intake?
Old Oct 21, 2007 | 06:44 PM
96 SOHC VTEC's Avatar
Default Re: Eleanor's HPDE Track Car... (1200 Hobos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1200 Hobos &raquo;</TD></TR><TR><TD CLASS="quote">
What color is it?
One thing. Aren't you supposed to wrap the header with that tape as opposed to the intake?</TD></TR></TABLE>
It is a great car! I'm glad I'm fortunate enough to drive it.
I forget what was used to spray the floor. I'll try and find out. I know that both colors are Championship White though.
The header is only wrapped by the oil pan to keep heat down. It doesn't hurt to put the wrap on the intake though.
Old Oct 21, 2007 | 06:54 PM
EleanoR's Avatar
Default Re: Eleanor's HPDE Track Car... (96 SOHC VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 SOHC VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
The header is only wrapped by the oil pan to keep heat down. It doesn't hurt to put the wrap on the intake though. </TD></TR></TABLE>
There are theories against this and from what I have experienced both having it wrapped with header wrap, wrapped in heat shield tape (silver stuff), or simply not having it wrapped it seemed to me the car didn't feel like it was bogging due to extreme heat in the engine bay with the header wrap on it.
After this season I am going to build something similiar to the Realtime setup where is a forced air intake system right off the headlight. This should give us the best results. Right now with no fender liner the filter gets dirty VERY easily and i have to clean it after every weekend (at least shake it out to get the rubber and rocks out of it).
Old Oct 21, 2007 | 06:57 PM
pork's Avatar
I watched the whole video and it looked like a shitload of fun... nice car
Old Oct 21, 2007 | 06:59 PM
post-ej1's Avatar
nice race car, but the outside is done up nasty
Old Oct 21, 2007 | 07:03 PM
hon da top's Avatar
Default Re: Eleanor's HPDE Track Car... (KILLER_EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLER_EK9 &raquo;</TD></TR><TR><TD CLASS="quote">Sick...
Old Oct 21, 2007 | 07:09 PM
vietnamezerice's Avatar
Default Re: Eleanor's HPDE Track Car... (hon da top)
nice! I'd like to see some videos
Old Oct 21, 2007 | 07:11 PM
Default Re: Eleanor's HPDE Track Car... (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">nice! I'd like to see some videos </TD></TR></TABLE>
Two videos are linked under the last picture.
EleanoR's Avatar
Old Oct 21, 2007 | 07:16 PM
itsmarcnotmark's Avatar
nice track car
Old Oct 21, 2007 | 07:17 PM
1200 Hobos's Avatar
If you could get me the name of that stuff that would be great. I'm in the process of redoing my interior and it just like yours except it's a white DA. Still have to remove a **** load of sound deadening around the front half of the interior. I was just going to use regular white spray can paint after I sand it down abit to smooth it out. Is that stuff you used anything special? It looks kind of rough edged.
Also, where'd you get those dummy headlights/covers?
SHG_Mike's Avatar
I love to see cars built like this... its an inspiration keep up the good work
Old Oct 21, 2007 | 07:24 PM
neof69's Avatar
Are those Volk CE28N's?? What are the specs on them??
Old Oct 21, 2007 | 07:26 PM
Chris.'s Avatar
Honda-Tech Order of Merit
that thing looks like a friggin monster
Old Oct 21, 2007 | 07:31 PM
get RIGHT's Avatar
Default Re: Eleanor's HPDE Track Car... (Chris.)
That's awesome.
Old Oct 21, 2007 | 07:32 PM
EleanoR's Avatar
Default Re: Eleanor's HPDE Track Car... (neof69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neof69 &raquo;</TD></TR><TR><TD CLASS="quote">Are those Volk CE28N's?? What are the specs on them??</TD></TR></TABLE>
Yes they are.
I stumbled across these from a vendor that was sitting on them for some time due to a non paying customer. They came to me flat black (without the red lip) and are 15x7. Weigh approximately 9.2 pounds per wheel and I will certainly vouch for that. I can't remember the offset - but I'll stab at 43 offset. If you need me to verify I will.
Old Oct 21, 2007 | 07:34 PM
Two videos are linked under the last picture. </TD></TR></TABLE>
shows how much attention i have
