tire question
definately. you need to put tires on the car that are OEM specs or have the same diameter without rubbing
185 70 r14 is about the same as 195 65r15
the tire size are not only different by the label but from a visual stand point its also very obvious the 195 is bigger. I used to use those tires to hide the gaps or put on stock springs and make it look lifted. heh.
crxaddikt
12
Feb 6, 2011 05:28 PM
theineffable
Honda Civic (2001 - 2005)
Nov 25, 2009 12:58 PM
