1-2 shift question
Old Jun 20, 2002 | 10:58 PM
SweetR's Avatar
Default 1-2 shift question
wassup
ill make this short. When racing our type r's, the tires will screech at the 1-2 shift. I never get the screeching. All i get is some madass wheelhop in between shifts?
Anyone know the reason? is it me or the car...
Thanx
Old Jun 20, 2002 | 11:14 PM
Tommy_Gunns's Avatar
Default Re: 1-2 shift question (SweetR)
That's impossible. Your getting wheel hop in neutral (clutch in).
I get screeching during 2-3 shifts as well as 1-2 shifts.
Old Jun 20, 2002 | 11:37 PM
DC5-R's Avatar
Default Re: 1-2 shift question (Tommy_Gunns)
Same here
Old Jun 20, 2002 | 11:39 PM
01PYITR's Avatar
Default Re: 1-2 shift question (BuddyClub)
and sometimes 3-4 shifts, but rare.
Old Jun 20, 2002 | 11:43 PM
SurferX's Avatar
Tires.
Old Jun 21, 2002 | 12:47 AM
R3dL1n3's Avatar
I sometimes get that but only when i cant get traction like in the wet.
Old Jun 21, 2002 | 12:48 AM
R3dL1n3's Avatar
Default Re: 1-2 shift question (01PYITR)
Damn is ur car stock?? u must shift really really really fast.....
Old Jun 21, 2002 | 12:49 AM
DutchITR1689's Avatar
Default Re: 1-2 shift question (zxcv123)
That happens sometimes if you have a JDM header.....
Old Jun 21, 2002 | 03:11 AM
Black SVT's Avatar
Lol..someone must not have good tires.The faster you shift the less of a chance you are going to"screetch"the tires.A good ,fast power shift won't even break the tires loose.It should be seemless.
Only if I could shift like I did in the R in my new car.
Old Jun 21, 2002 | 03:29 AM
JSITR's Avatar
Default Re: 1-2 shift question (Black SVT)
Im sure that I could break the tires loose on the 1-2 shift, but why would you what to? I thought the idea was to get as much power to the ground as possible and my understanding is that wheelspin=loss of power to the ground for that time period. I try to make my 1-2 shift as fast and seemless as possible with just the right amout of that great yank (<--- Technical term) forward. Every once in a while ill mess up and get a little wheel spin, but not much, just a mini squeek.
Old Jun 21, 2002 | 05:08 AM
1GreyTeg's Avatar
Default Re: 1-2 shift question (SurferX)
Tires.
I just swapped on some near new stock rubber last week. Compared to the old wasted ones which used to hop and then grip way back when new, over time with mileage they just started to spin regardless of conditions. Of course traction is a bit more of an issue with my car compared to stock.
With the newer tires, I get the hop again and ALOT better grip. It's controllable, and it hunts if the launch is too aggressive but nice easy starts work well.
Wanna cure the hop? Heres a few things to try;
1. Better clutch control/launching technique
2. Tire pressure/ find the balance, too high and it will just spin, too low and it could spin on the rim and or just give poor cornering characterisitcs and roll over. In the middle is Just Right...
3. Stiffer Motor mounts, like Mugen
4. Z10 radius arms
Good luck,
A.
Old Jun 21, 2002 | 05:27 AM
JohnnyK's Avatar
Default Re: 1-2 shift question (1GreyTeg)
Perhaps also:
5 - Higher spring rates for front springs.
[EDIT]
You might also want to take a look at the Best Motoring videos as well. I learned a lot about shift/clutch technique, especially smooth shifting, from them
[/EDIT]
[Modified by JohnnyK, 9:31 AM 6/21/2002]
Old Jun 21, 2002 | 06:43 AM
ckkl's Avatar
Default Re: 1-2 shift question (JohnnyK)
Perhaps also:
Is that right? I would've thought softer springs would give better traction...
Old Jun 21, 2002 | 06:46 AM
JohnnyK's Avatar
Default Re: 1-2 shift question (ckkl)
I thought stiffening the front would reduce wheel hop... please correct me if I am wrong!! Hate it when that happens!
Old Jun 21, 2002 | 07:13 AM
Turtle's Avatar
I try NOT to have the wheels slip (I'll leave it for the drag queens) j/k. Smooth, quick shifting should somewhat limit this. As for your problems...what tires are you running? Tires and shifting should be the first place to look into for what your talking about.
Old Jun 21, 2002 | 08:23 AM
PM-Performance's Avatar
Default Re: 1-2 shift question (401-2001)
it depends on how hard i shift, , , ,if i shift really hard i get wheel hop all the way up to 4th gear .
and lighter shifts they just squell and spin up to 4th.
Old Jun 21, 2002 | 08:27 AM
ITR21's Avatar
yeah when i first had my brand new potenzas i only got wheel hop from 1-2 but now they are worn down and they screeeetch. definately your tires.
Old Jun 21, 2002 | 10:07 AM
RiCE On IcE 2's Avatar
Default Re: 1-2 shift question (ITR21)
since were sorta on this topic.. when racing... what do u rev to at the line.. I normally do about 2.. and from 1-2.. do u drop the clutch.. or let out a little slower so theres no skirk... cus honestly it feels faster when I dun drop it and let it out a little slower.. but mayb e I'm jsut tripping lol
Old Jun 21, 2002 | 10:20 AM
Default Re: 1-2 shift question (scmdl26)
on the street i go from idle , if i launch they will break loose to easy,. on the track i drop it at 7k +
Old Jun 21, 2002 | 12:10 PM
Default Re: 1-2 shift question (itr206)
u drop it at 7K?... dun it take a while to get traction or u talking bout on slicks.. cus thas way high
Old Jun 21, 2002 | 12:11 PM
thats on slicks dude, , like i said on streets i dont even launch cuz i can never get traction , i go from idle or like 1500 or so .
Old Jun 21, 2002 | 12:16 PM
I was bout to say.. 7K on streets... I'd prolyl just sit there lol
Old Jun 21, 2002 | 12:31 PM
BlkITR #1404's Avatar
i get 1-2 sometimes.......mostly at night when its cool outside and my car is runnin good......2-3 ALL DAY!......but then again, i have clutch/flywheel so my shifts are hard and the power still is there.......clutch and flywheel is the greatest mods..
Old Jun 21, 2002 | 12:43 PM
Incognito's Avatar
Default Re: 1-2 shift question (BlkITR #1825)
Dumping the clutch at 7K on street tires, I'll probably break both axles and intermediate shaft from wheel hop
As long as your clutch is 1/2 way decent, the tires should spin on the 1-2 shift, and chirp on the 2-3 shift, and soemtimes on the 3-4 shift. With most aftermarklet clutches, you'll get up the chirp up to the 3-4 shift.
To chirp tires, shift AT redline. Don't let RPMs drop too much in between shifts. if U really don't care about your tranny, powershift it (banging gears without letting go of the gas). Good luck.
Old Jun 21, 2002 | 12:51 PM
Default Re: 1-2 shift question (Incognito)
yo ingognito, you gona be at summerslam with the R , Ill [prob be there both days , , deff sunday , im gonna try to get the z10's on and the coilovers ,. motor moutns and some little **** on before then .
