speedometer dont work????
Old Oct 21, 2007 | 11:05 AM
lazii_boi08's Avatar
Default speedometer dont work????
My cousin owns a 90 CRX non SI with a manual tranny. and his speedometer dont work and he bought the car like that and he has tried swapping clusters and still same problem I mean can it be a fuse???? or his tranny's speed sensor??? well i would really appreciate if yall could prolably determine what might be the problem
Thanx in advance
If you have somthin rude or not nice to say please keep it to yourself Thank you
Old Oct 21, 2007 | 11:56 AM
grog's Avatar
Default Re: speedometer dont work???? (lazii_boi08)
the cable probley snapped. you might be able to remove both ends(from tranny and cluster)and see if it spins freely. maybe hook it up to a drill, then spin one end, and make sure the other end spins also.
also the speedo and compenents are all mechanical, gears and such, theres absolutely no electrical components.
and I assume that when you swaped clusters you made sure the speedo cable was "clipped" or snapped in place ( on the back of the cluster)
Old Oct 21, 2007 | 12:19 PM
BlueRex1020's Avatar
Default Re: speedometer dont work???? (grog)
i have the same problem when i changed from my dx to si trans, my speedo didnt work...the speedo in the si trans refuses to come out though..ive tried everything..
Old Dec 27, 2007 | 04:22 PM
JRZ88DX's Avatar
Default Re: speedometer dont work???? (BlueRex1020)
i've got this problem too
i changed my speedo cable about two months ago
and just swapped the cluster with one from ebay
anybody know what the problem could be?
Old Dec 27, 2007 | 04:56 PM
JokerTypeR's Avatar
To he who can't remove his speedo cable from the tranny...pull back the rubber boot and slide out the locking hairpin type thing. Then slide out your cable.
To he who can't get the speedo to work...make sure the speedo cable is ALL THE WAY IN at the tranny and the back of the cluster...
Old Dec 27, 2007 | 05:03 PM
JRZ88DX's Avatar
Default Re: (JokerTypeR)
good idea
Old Dec 27, 2007 | 11:02 PM
JokerTypeR's Avatar
Default Re: (JRZ88DX)
Just play with. As stated earlier, it's all mechanical. Nothing is electrical unless you've converted stuff...and if you did, you'd know what I'm talking about. The good side of it being mechanical makes it easy to troubleshoot. Either the cable isn't turning because one side isn't hooked up...the cluster is jacked up...or your tranny gear is jacked up. I doubt you've hit two bad clusters, and to mess a tranny up like that takes skill. So that leaves only one option...
Old Dec 28, 2007 | 05:38 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
I have a spare cable in my garage if you want to swap it out and see if that's the problem.
Old Dec 29, 2007 | 06:31 PM
JRZ88DX's Avatar
so after changing the lcuster i decided to see if my old cluster was actually broken by taking an allen key and putting it in the speedo hole and spinning it. It works.
i spent today at a junkyard getting parts and haven't checked the tranny connection.
i asked my father( former mechanic) and he said that it oculd be the gear in the tranny.
my question, is it possile to replace this gear, is it hard to find and will it be really difficult?
Old Dec 30, 2007 | 01:20 AM
Hamstr323's Avatar
dear god! dude check the cable first please!
Old Dec 30, 2007 | 09:15 AM
dr_latino999's Avatar
Default Re: (Hamstr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">dear god! dude check the cable first please! </TD></TR></TABLE> It's process of elimination. You want an easy way to check the cable without pulling out both ends? Remove the cable from the cluster so it stands up while you're driving, and just touch it and see if it is spinning.
Old Dec 30, 2007 | 11:59 AM
JRZ88DX's Avatar
yea i'm gonna, i just wanted some input to see that if indeed the lcuster is fine and it is in all the way if it will be a pain hte the ***
Old Dec 30, 2007 | 11:02 PM
mario_pic's Avatar
lol see thiss is the reasion i did a 96 si cluster swap lol got sick of the dam cable lol
GPark
Feb 9, 2013 07:13 PM
turbo-crx
Oct 20, 2008 12:05 PM
FloatingCloud_9
Jun 13, 2007 10:03 AM
ryyo
12
Apr 21, 2007 10:53 AM
rasta420
Jul 7, 2002 07:50 PM
