Help! my car wont start for some reason...
Old Oct 21, 2007 | 11:00 AM
ShinotakuX's Avatar
Default Help! my car wont start for some reason...
i need help asap, i have to pick up my little sister at school, I cant start the car but it works fine yesterday, the battery is good but i dont know why it wont start, I pushed the clutch and start the engine but it wont start, help. and I dont hear any clicking noises when I start the car. help!!
Old Oct 21, 2007 | 11:18 AM
ShinotakuX's Avatar
Default Re: Help! my car wont start for some reason... (ShinotakuX)
help!?
Old Oct 21, 2007 | 11:22 AM
ke98248's Avatar
does it make any sounds when you try and start it?
What have you changed since the last time you drove it, anything?
Could be the starter, fuel pump, a million things, need more info.
Old Oct 21, 2007 | 11:26 AM
ShinotakuX's Avatar
Default Re: Help! my car wont start for some reason... (ke98248)
all i hear is a little humming sound, but no clicking, the battery is good all lights work and everything, what could go wrong?
Old Oct 21, 2007 | 11:27 AM
ke98248's Avatar
Just to check, do all of your accessories work: i.e. --> Radio, headlights, vents, etc..
Old Oct 21, 2007 | 11:30 AM
ShinotakuX's Avatar
yes they all work fine.
Old Oct 21, 2007 | 11:47 AM
gooberguy31's Avatar
could just be the battery connections........taking baking soda and water mix em' together and take paper towel dip it in and wipe down your posts or connections.....depending on what you have........then make sure their tight
Old Oct 21, 2007 | 11:53 AM
ShinotakuX's Avatar
the battery is fine tho, cos all lights work, powerwindows, sunroof, blinker light all work. but i couldnt start the car, pls help
Old Oct 21, 2007 | 12:57 PM
ShinotakuX's Avatar
oh, i just found out something, when i put the key in ignition(before cranking) the seatbelt and ebrake indicator lit up as usual, but the oil and batter indicator lit up too, what does that mean? maybe this will help me?
Old Oct 21, 2007 | 01:03 PM
HondaKid936's Avatar
do u hear your starter clickling?
Old Oct 21, 2007 | 01:05 PM
ShinotakuX's Avatar
i dont hear any clicking, but i hear a little hum sound. what could be wrong?
Old Oct 21, 2007 | 01:42 PM
ShinotakuX's Avatar
also, when I try to crank it(start the engine) it doesnt do anything, so sound or whatsover, its like when the alarm is on, it wont turn on the engine, so my guess might be something wrong with the immoblizer? where is the immoblizer? i want to check that out. thanks.
Old Oct 21, 2007 | 01:59 PM
michael123's Avatar
have u checked if u have any spark??
Old Oct 21, 2007 | 02:08 PM
ShinotakuX's Avatar
how do u check?
Old Oct 21, 2007 | 02:21 PM
pauley_lsvtec's Avatar
first off you shouldent check spark and cant check spart cause the damn thing wont crank over. the first thing i would do is get under the dash and unplug the clip that plugs into the sensor on the clutch pedal and jump the plug with a paper clip or a piece of wire if this indeed fixes the problem the clutch safty switch is bad and needs to be replaced and if you dont feel like replacing it just cut the wires and twist them together.
Old Oct 21, 2007 | 02:58 PM
ShinotakuX's Avatar
still no luck, what could really went wrong? battery is good, there is no CEL, and just couldnt start the car.
Old Oct 21, 2007 | 03:11 PM
then i would expect a falty ingtion switch or mabe a blown fuse your going to have to get into a wireing diagram and trace it to find the problem
Old Oct 21, 2007 | 03:47 PM
LS-V_T_fullrace_EG's Avatar
this happened in my ef a lot... there are two wires on your starter... one is your positive cable and the other is a little single wire female connector covered by rubber boot which slides onto the male input on your starter next to the positive cable... also make sure the positive cable is tightly bolted down lmk if this helps
Old Oct 21, 2007 | 03:53 PM
ShinotakuX's Avatar
Default Re: Help! my car wont start for some reason... (LS-V_T_fullrace_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-V_T_fullrace_EG &raquo;</TD></TR><TR><TD CLASS="quote">this happened in my ef a lot... there are two wires on your starter... one is your positive cable and the other is a little single wire female connector covered by rubber boot which slides onto the male input on your starter next to the positive cable... also make sure the positive cable is tightly bolted down lmk if this helps</TD></TR></TABLE>
can u please point me out the location of this process? I would like to get my car start up by tonight, i have a calculus midterm tomrw
Old Oct 21, 2007 | 04:05 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinotakuX &raquo;</TD></TR><TR><TD CLASS="quote">
can u please point me out the location of this process? I would like to get my car start up by tonight, i have a calculus midterm tomrw </TD></TR></TABLE>
wow, i am amazed on how everybody posts on here what it might be, but no one posts the obvious.
OP, did you ever think you starter is just bad. you should have it removed and tested. if that checks out, then proceed to the next step!
and you mention immobilizer? what is that?
Old Oct 21, 2007 | 04:10 PM
629RWHPmustang's Avatar
tell her to walk lol
Old Oct 21, 2007 | 04:19 PM
drtysohc's Avatar
sounds like something with your alarm to me
Old Oct 21, 2007 | 04:30 PM
ShinotakuX's Avatar
sorry for a noob question, but is the starter locate in the engine bay?
Old Oct 21, 2007 | 04:33 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinotakuX &raquo;</TD></TR><TR><TD CLASS="quote">sorry for a noob question, but is the starter locate in the engine bay? </TD></TR></TABLE>
yes, your starter is on the right (passenger) side of the car. right on top connected to the tranny (under the air filter runner).
Old Oct 21, 2007 | 04:36 PM
ShinotakuX's Avatar
omfg!! I figured out what went wrong, the wires that connected to the starter got cut off, so I solder it back and it start up the car. I'm so proud of myself now cos I dont know much about car and I spent the whole day today. but thanks everyone, great H-T community.
