96 Accord - no heat blowing on the passenger side vent.
I have a problem where there is no heat coming out of the vent on the passenger side. The vent above the glove box and below the passenger side airbag. I get heat/air on the driver side and middle vents but not the passenger side. I have no clue what the issue could be as nothing seems loose. Anyone have any ideas?
Thanks in advance.
Modified by rb_888 at 8:52 AM 10/21/2007
Thanks in advance.
May need to pull the glove box and check the vent system, tube. There sould be no vent doo to seperate the left and right sides.
might have somethin jammed in there or int the cowl under where your wipers are... not sure but thought i would drop my $.02
Brian Gareau
Jan 24, 2013 03:48 PM
