vss plug wiring help
Old Oct 20, 2007 | 07:37 PM
urquidezj's Avatar
Default vss plug wiring help
si i have this 94 eg, speedo didnt work, so i got cluster, nothing, then looked around vss area and saw that it was broken, like where its bolted, so i get a known working one, put it in and nothing again, so i check wires and its obvious that it was fucked with, did a massive search and came up with this. the plug is c112 according to shop manual, c112 has three wires coming out of it. yel/wht is for the signal, yel/blu is for power, blck is ground. plug outlets are numbered as a 123 on the plug schematic it gives this order, 1 is yel/wht, 2 is yel blue, 3 is blk. wire schematic gives different order, yel/blu for 1, yel/wht for 2, and blck for three, so which one is correct?? i dont know where to go from here. they are last 2 pages on the online manual and also page 1243 gives some help. please help me i dont want to be speeding. thanks in advance.
Old Oct 21, 2007 | 01:58 AM
urquidezj's Avatar
Default Re: vss plug wiring help (urquidezj)
bump
Old Oct 21, 2007 | 02:20 AM
BlueIntegraBoy's Avatar
I just took this picture for you...
Old Oct 21, 2007 | 03:14 PM
urquidezj's Avatar
Default Re: vss plug wiring help (BlueIntegraBoy)
thanks integ boy, i checked everything, i noticed that wires where in correct order but where dirty and not makin good contact, everything is fixed now.
Old Jan 30, 2008 | 07:27 AM
kudude's Avatar
bump.
I have the same problem, mostly that I need the wiring order. Can whoever posted the pic fix it?
thanks
sammyboy1978
Honda CR-V & Element
Mar 4, 2012 10:22 PM
Jonknee
Jul 18, 2007 10:39 PM
503_EF9
May 21, 2007 10:50 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
jerbear!
May 9, 2005 02:47 PM
