FS: 1995 Fully Built Turbo Acura Integra Over 500whp All Fresh drivetrain
Old Oct 20, 2007 | 02:24 PM
501hpintegra's Avatar
Default FS: 1995 Fully Built Turbo Acura Integra Over 500whp All Fresh drivetrain
Just as it states above. I am selling this car to move onto another project. I am asking $18,000obo willing to take partial trades. It has a fresh drive train including motor( top and bottom) Trans, turbo,sensors,exhaust, and a fresh tune by King. I provided a list below.
I have receipts and documentation
®Balanced and Blue Printed & Sleeved B18C1 by King Motor Sports
®ITR Cams
®J E Pistons
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®New Mugen low temp thermostat
®Samco red coolant hoses
®J G Intake Manifold
®King Big bore throttle body
®LoveFab Ram Head exhaust manifold (2800° Ceramic Coated)
®Moroso 5 Qt oil pan
®Precisions version of the Garrett twin scroll gt35r turbo– Polished housing (2800° Ceramic Coated Turbo Housing)
®40mm Tial Wastegate
®HKS sequential blow off valve
®Integra type R cylinder head Port matched, 3-angle competition valve job
®Type R Cams
®Supertech valve train
®ARC intercooler
®Mugen Hard Motor Mounts
®Fluidyne 40mm radiator
®Precision 1000cc injectors
®3-inch stainless steel exhaust
®3-inch stainless steel down pipe (2800° Ceramic Jet Coated)
®Walbro fuel pump 225 LPH
Aeromotive FPR #13109 with -6&10 SS lines
®AEM fuel filter, fuel rail, cam gears
®KMS oil catch can
®Magnacore 8.5 plug wires
®MSD full sport compact ignition
®Custom upper & lower intercooler pipes
®ACT stage 3 six puck racing clutch
®Act 8LB Flywheel
®Quaife Limited slip
®Built Trans (hardened and carbon coated components)
®Enkei J10 17x7 rims w/Falken Azenis rt615 205 40 17
®Front Brembro cross-drilled and slotted rotors
®Rear Brembro cross-drilled rotors
®Brembro front & rear brake pads
®Tokico Illumines coil-overs
®DC sports front & rear strut tower braces
®Hondata P72 ECU
®Hondata S300 computer system
®Hondata Independent gear boost controller
®Sparco Flash 5 steering wheel
®Sparco Pedal Set
®Full chrome moly roll cage
®Sparco racing seats
®Sparco 4 point Harnesses
®Jdm Air bag Eliminator Plate
®JDM Center counsel Eliminator
®JDM double Din Stereo Eliminator Plate
®Mugen Sweat Socks
® 01 ITR Stock Front Bumper cover
® 98 Stock Head lights
® 98 Stock Rear Bumper
®Gauges auto meter phantom series (fuel pressure, oil pressure, volts, boost, nitrous,(never used nitrous it was for my intercooler sprayer)
Air/fuel) 5.5” auto meter tachometer with shift light
®Was dyno tuned by King Motorsports New Berlin, WI
Modified by 501hpintegra at 5:53 PM 10/20/2007
Modified by 501hpintegra at 9:46 AM 10/21/2007
Old Oct 21, 2007 | 08:48 AM
Default Re: FS: 1995 Fully Built Turbo Acura Integra Over 500whp All Fresh drivetrain (501hpintegra)
bump new price
Old Oct 21, 2007 | 06:46 PM
kermit97's Avatar
kool car hows the car run at the track time wise
Old Oct 22, 2007 | 08:41 AM
Default Re: (kermit97)
imed
Old Oct 22, 2007 | 12:32 PM
Default Re: (501hpintegra)
Bump willing to bargin. Make offers But no low ballers or haters please thanks
Old Oct 24, 2007 | 08:19 AM
bump again
Old Nov 15, 2007 | 12:48 PM
98tegLSvtec's Avatar
BUMP.....Can you say super clean!
501hpintegra
Jul 30, 2008 06:08 PM
501hpintegra
Jun 21, 2008 06:20 AM
501hpintegra
Oct 24, 2007 08:20 AM
501hpintegra
Aug 13, 2007 12:38 PM
501hpintegra
Aug 10, 2007 08:52 AM
