Name that Plug...Cleaning up engine harness
Old Oct 20, 2007 | 11:28 AM
ozrednsx's Avatar
Default Name that Plug...Cleaning up engine harness
Alright well im cleaning up my harness and doing a wiretuck but after taking off all the electrical tape and plastic wire loom there was a random plug that was not hooked up.
Here are the pictures of it...Its a 3 pin plug with green/white, yellow/white, solid yellow wires. Can i depin and remove this plug overall?
Old Oct 20, 2007 | 12:06 PM
lilsicsoul's Avatar
i have that same plug..unplugd...a/c plug i think,,,correct me if im wrong,,
Old Oct 20, 2007 | 12:08 PM
ozrednsx's Avatar
Default Re: (lilsicsoul)
im not sure...the car was running without it plug into anything.
I want to take it off...im redoing my whole harness and dont want to end up needing the plug later down the road.
but either way im not goign to be running a/c
Old Oct 20, 2007 | 02:01 PM
lilsicsoul's Avatar
bump who noes this?
Old Oct 20, 2007 | 02:07 PM
KrenzyRyan's Avatar
Hmm, not recognizing it... If the plug is from the engine bay, then I know its not for the AC.
Old Oct 20, 2007 | 02:44 PM
black0hatch's Avatar
Default Re: (KrenzyRyan)
its on the engine harness or body harness? and where was it at?
Old Oct 20, 2007 | 06:30 PM
ozrednsx's Avatar
Default Re: (black0hatch)
its on the engine harness...
alright the green/white is spliced into another green/white wire which is plugged into the side of the head below the vtec solenoid.
solid yellow is connected to the big plug where the injectors are wired to.
sorry id be more specific but im sorta running late for work haha.
Ill take pictures where the wires run to...thanks for the help.
Old Oct 21, 2007 | 11:05 AM
ozrednsx's Avatar
Default Re: (Dustin_Pierce)
did you remove it?
Im thinking of just taping it up rather than removing it
Old Oct 21, 2007 | 11:46 AM
tougetuned_ef's Avatar
Default Re: (ozrednsx)
just leave it. if it ran fine before than dont mess with it. just tape it up and forget a bout it.
Old Oct 21, 2007 | 01:37 PM
ozrednsx's Avatar
naw no a/c
no plans of ever having ac again.
Old Oct 21, 2007 | 01:38 PM
Tippyman's Avatar
Then just depin it, and tape the wires up and re-loom them. If you really need it again one day, then untape them and stick the wires back in the plug.
Old Oct 21, 2007 | 01:51 PM
DustinRose's Avatar
Default Re: (tougetuned_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougetuned_ef &raquo;</TD></TR><TR><TD CLASS="quote">just leave it. if it ran fine before than dont mess with it. just tape it up and forget a bout it.</TD></TR></TABLE>
this is a supreme idea, its what i did
Old Oct 22, 2007 | 12:14 AM
ozrednsx's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Then just depin it, and tape the wires up and re-loom them. If you really need it again one day, then untape them and stick the wires back in the plug.</TD></TR></TABLE>
i dont know kind of a noobish question...if i were to depin it i have to make sure the pins dont make any sort of contact right?
but thanks guys...im pretty much done organizing all the wires and im getting ready to re loom everything with fire proof loom and heat shrink tubing everything
Alex V
Jul 5, 2019 10:46 AM
carlos8
Feb 24, 2017 11:28 AM
REDEM1FTW
13
May 11, 2010 10:08 AM
sonic47
13
Feb 10, 2010 03:23 AM
honda-mini
Apr 14, 2007 04:58 AM
