Throttle body/Intake Manifold Too Big?
Old Oct 20, 2007 | 11:23 AM
sloweh3's Avatar
Default Throttle body/Intake Manifold Too Big?
I recently picked up a 92 si hatch w/ an obd0 b16 swap. The car acts really sluggish up until around 4-5k. I was wondering if the intake manifold and throttle body combo was too big for the motor.
Currently it has a BDL 68mm throttle body and an aebs intake manifold, port matched to the throttle body. The intake manifold has also been cut open and ported more, then re-welded back. I'm not sure how much was ported though. I was wondering if this combo was too big for just a stock b16. Thanks.
Old Oct 20, 2007 | 11:36 AM
BlackoutVTi's Avatar
Default Re: Throttle body/Intake Manifold Too Big? (sloweh3)
You sound like you may benefit from portmatched intake ports on your head, and a polish job inside. Do you have an intake that will allow the increased flow of the IM and throttle body?
The sudden steps between diameters that your intake air flows past may be causing critical turbulence.
Also, you may want to check your TPS, as that can be a cause for your engine to attempt to pull timing at innappropriate times, causing the engine to seem suspiciously sluggish.
Old Oct 20, 2007 | 08:54 PM
sloweh3's Avatar
Default Re: Throttle body/Intake Manifold Too Big? (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">You sound like you may benefit from portmatched intake ports on your head, and a polish job inside. Do you have an intake that will allow the increased flow of the IM and throttle body?
Also, you may want to check your TPS, as that can be a cause for your engine to attempt to pull timing at innappropriate times, causing the engine to seem suspiciously sluggish.</TD></TR></TABLE>
I'm running a j's racing intake (the big whale *****)
Old Oct 20, 2007 | 11:04 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">The sudden steps between diameters that your intake air flows past may be causing critical turbulence.</TD></TR></TABLE>
Who said that's bad?
68mm is probably too big. What intake manifold and cams are you using?
Also, port-matching the throttle body to the intake manifold without an anti-reversion step will extend the intake manifold plenum into the intake piping. This eliminates the possibility of taking advantage of captured pressure waves. As a result, you will lose potential power.
Old Oct 21, 2007 | 07:28 AM
sloweh3's Avatar
Default Re: Throttle body/Intake Manifold Too Big? (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">
Also, port-matching the throttle body to the intake manifold without an anti-reversion step will extend the intake manifold plenum into the intake piping. This eliminates the possibility of taking advantage of captured pressure waves. As a result, you will lose potential power.</TD></TR></TABLE>
AEBS intake manifold and stock cams. Internally, the motor is stock, it's just bolt ons that were put on before I bought the car.
Old Oct 21, 2007 | 10:44 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweh3 &raquo;</TD></TR><TR><TD CLASS="quote">AEBS intake manifold and stock cams. Internally, the motor is stock, it's just bolt ons that were put on before I bought the car.</TD></TR></TABLE>
How does the intake manifold compare to stock?
I'm almost certain that the throttle body is too big, but I'm not familiar with the intake manifold.
Old Oct 21, 2007 | 11:29 AM
sloweh3's Avatar
I'm almost certain that the throttle body is too big, but I'm not familiar with the intake manifold.</TD></TR></TABLE>
I believe that intake manifold is just a little bigger than an itr intake manifold, but since it has been ported more, the ports are bigger than one you would buy from kteller.
Old Oct 21, 2007 | 11:36 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweh3 &raquo;</TD></TR><TR><TD CLASS="quote">I believe that intake manifold is just a little bigger than an itr intake manifold, but since it has been ported more, the ports are bigger than one you would buy from kteller.</TD></TR></TABLE>
I would call them to see what they recommend.
Old Oct 21, 2007 | 12:13 PM
sloweh3's Avatar
ok, thanks for the help
Old Oct 21, 2007 | 01:52 PM
Redbone's Avatar
I thought that PNP the head without upping the compression would actually be detrimental to making more power? What else have you got done to the motor?
Old Oct 21, 2007 | 02:53 PM
sloweh3's Avatar
Default Re: (Redbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redbone &raquo;</TD></TR><TR><TD CLASS="quote">I thought that PNP the head without upping the compression would actually be detrimental to making more power? What else have you got done to the motor?</TD></TR></TABLE>
just a stock internal obd0 b16. DC Sports 4-1 2.5" header, Omnipower 2.5" test pipe, Apexi NOIR catback, AEM Fuel Rail and regulator, J's Racing Intake, and a street tune on chrome
Old Oct 21, 2007 | 05:46 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redbone &raquo;</TD></TR><TR><TD CLASS="quote">I thought that PNP the head without upping the compression would actually be detrimental to making more power?</TD></TR></TABLE>
It depends on the port job.
You can gain or lose power with porting/polishing no matter what setup you have. It depends who's doing it and how good of a job they do.
Old Oct 22, 2007 | 09:29 AM
sloweh3's Avatar
Default Re: (ddd4114)
You can gain or lose power with porting/polishing no matter what setup you have. It depends who's doing it and how good of a job they do.</TD></TR></TABLE>
yea, i just found an itr intake manifold and tb for a pretty good price, so i'm gonna pick that up now and sell my old setup. hopefully after a retune i'll have much better results
JDM_Matter
Feb 5, 2012 09:40 AM
JDM_Matter
Feb 4, 2012 10:24 PM
pbink
Oct 18, 2005 05:18 AM
Duck Sauce
Nov 28, 2001 08:47 AM
