Oil check light came on and oil is not low.help!!!
Old Oct 20, 2007 | 11:11 AM
MUGEN_EG95's Avatar
Default Oil check light came on and oil is not low.help!!!
I own a 95 honda civic ex. I was driving yesterday and my engine light kind of flickered a couple of times, right after that the oil light didi the same. Then it just stayed on. I checked my oil and it was perfect. So wats wrong with my car????Please help!!!
Old Oct 20, 2007 | 11:13 AM
Syndacate's Avatar
Default Re: Oil check light came on and oil is not low.help!!! (MUGEN_EG95)
The oil idiot light has nothing to do with how high or low the oil is - it has to do with your oil pressure.
If you're throwing an oil light that means you have insufficient oil pressure. Might wanna look at the pump on that one - see how it's doing.
Old Oct 22, 2007 | 03:50 PM
MUGEN_EG95's Avatar
Default Re: Oil check light came on and oil is not low.help!!! (Syndacate)
Damn wished i would of checked it out sooner...cuz my motor went after driving back from college. It shuddered and died while it was rolling. It would start up but will die after a few seconds if i wouldn't give it gas. It makes a rattling squeaky noise so i'm guessing the pistons are rubbing the cylinder walls.
Old Oct 23, 2007 | 01:50 PM
fin781's Avatar
im thinkin your bearings are disenegrated. into sand
Old Oct 24, 2007 | 11:43 AM
MUGEN_EG95's Avatar
Default Re: Oil check light came on and oil is not low.help!!! (fin781)
So would u suggest me buying a new motor or fix it??
Old Oct 24, 2007 | 12:39 PM
instructor74's Avatar
If you are going to stay with the same motor you can pick that on up from any of the comp that inport japan motors complete for 350-500 plus shipping
Old Oct 24, 2007 | 12:45 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_EG95 &raquo;</TD></TR><TR><TD CLASS="quote">Damn wished i would of checked it out sooner...cuz my motor went after driving back from college. It shuddered and died while it was rolling. It would start up but will die after a few seconds if i wouldn't give it gas. It makes a rattling squeaky noise so i'm guessing the pistons are rubbing the cylinder walls. </TD></TR></TABLE>
the fact that you stated that the CEL flickered on makes me wonder if you knock sensor is going out, or is bad? do 95 civic ex even have a knock sensor?
but worst case scenrio, if you are losing oil pressure i would consider looking into the oil pump or headgasket.
the reason i say headgasket is, my D15 went out with a blown gasket. it was so bad i had the same problem you have when starting/driving the car. are you leaving clouds of smoke behind as you drive?
Old Oct 24, 2007 | 02:38 PM
MUGEN_EG95's Avatar
Default Re: Oil check light came on and oil is not low.help!!! (philosofy1)
I don't know if d15 motors have knock sensors. Anyways the motor is making a really loud knocking sound...kind of squeaky. Theres no trial of smoke so i don't think its my head gasket.
Old Oct 25, 2007 | 04:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_EG95 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if d15 motors have knock sensors. Anyways the motor is making a really loud knocking sound...kind of squeaky. Theres no trial of smoke so i don't think its my head gasket.</TD></TR></TABLE>
The ex has a d16z6 motor in it and you are correct there is no knock sensor on it. A loud knocking sound when running sounds like a spun rod bearing. Drain you oil and look for metal in it I bet you find some.
Old Oct 25, 2007 | 04:52 AM
michael123's Avatar
it might be ur bearings or maybe ur oil pump just craped out on u check the pump first tho,
Old Oct 25, 2007 | 07:24 AM
rivaladore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
no knock sensor on the d16z6
itzyaboyzeem03
Jul 1, 2016 04:40 PM
doublezerohatch
15
May 31, 2013 11:22 AM
runderwo
Mar 29, 2007 10:39 AM
boostedeghatch
31
Mar 2, 2005 12:58 PM
1 Cam Wonder
44
Nov 23, 2004 08:18 AM
