Brake Lights (Tail Lights) wont turn on Help!!!!!!!!
Hello All
I have a 00 civic ex and I notice that the brake lights wont tunr on, All Bulbs are ok, I check the tail light fuse and also remove them all fuses to make sure everything was ok, both from under the panel inside the car and the fuse box in the engine I did some research and found out that it could be the brake switch on the brake pedal well I order a new one and same thing no brake lights, the night lights will work but when pressing the brake pedal no brake lights both tail lights and the one in the middle up by the trunk, any hep will be appreciated.
PLease Help!!11
Ok a change all 4 brake lights bulbs and 1 uper midlle brake light bulb, switched to the same brake pedal switch and no luck. pleaseeeee
Sounds like a wiring problem, If you have a multimeter or a test light you should start checking for power and ground. get a hold of a wiring diagram if you can, all the bulbs share a common power and some common grounds.
Nderuso
Dec 30, 2019 08:43 AM
Caoboy
Jan 13, 2004 01:23 PM
