Serious problem with tuner toys rods
Old Oct 20, 2007 | 07:41 AM
SOHC_MShue's Avatar
Default Serious problem with tuner toys rods
Has anybody received any defective d series tuner toys rods? I ordered some and finally got around to looking at them closely and noticed the lower half of the bottom of the rod was not cut. It was just one big solid piece of metal
Old Oct 20, 2007 | 07:48 AM
.dave's Avatar
i HAS questions ?
Default Re: Serious problem with tuner toys rods (SOHC_MShue)
Wow haha talk about quality control.
Get ready for a barrage of "you get what you pay for" and other similar comments.
Old Oct 20, 2007 | 07:53 AM
locash's Avatar
Just dremel it out! Actually, Tuner Toys has some of the best customer service in the industry, and I'm sure they will do whatever it takes to make sure you are satisfied, just give them a call.. Obviously you received something that slipped through the cracks..
Old Oct 20, 2007 | 07:59 AM
SOHC_MShue's Avatar
Default Re: Serious problem with tuner toys rods (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Just dremel it out! Actually, Tuner Toys has some of the best customer service in the industry, and I'm sure they will do whatever it takes to make sure you are satisfied, just give them a call.. Obviously you received something that slipped through the cracks..</TD></TR></TABLE>
Yea thats what i figured. I already sent them an email. Just gotta wait until monday to get a response. At first i was like damn this is a high tolerance cut right here
Old Oct 20, 2007 | 10:39 AM
RC000E's Avatar
Post a pic of this, sounds interesting
Old Oct 20, 2007 | 12:08 PM
Brain3208's Avatar
EDIT: nevermind i misread the OP.
Modified by Brain3208 at 3:54 PM 10/20/2007
Old Oct 20, 2007 | 01:34 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Has anybody received any defective d series tuner toys rods? I ordered some and finally got around to looking at them closely and noticed the lower half of the bottom of the rod was not cut. It was just one big solid piece of metal </TD></TR></TABLE>
Take the bolts off and use something that wont scratch the rod to pull it apart. They are two pieces, but when they come brand new the line is very very fine and sometimes unnoticeable.
Old Oct 20, 2007 | 01:59 PM
SovXietday's Avatar
Default Re: Serious problem with tuner toys rods (OMG B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG B16 &raquo;</TD></TR><TR><TD CLASS="quote">
Take the bolts off and use something that wont scratch the rod to pull it apart. They are two pieces, but when they come brand new the line is very very fine and sometimes unnoticeable.</TD></TR></TABLE>
x2, are you dead sure they aren't cut? When I got my Eagles I couldn't tell they were two pieces, I looked at them for about 15 minutes with a WTF expression till I pulled the bolts out and pulled and saw a small crack open up.
Old Oct 20, 2007 | 02:03 PM
mike93eh2's Avatar
maybe its just stuck. they are hard to pull apart sometimes..
but you should of just spent the extra $50 and got real eagles.
Old Oct 20, 2007 | 02:32 PM
RC000E's Avatar
Default Re: (mike93eh2)
****...those rods are probably made by the same manufacturer...
Old Oct 20, 2007 | 03:06 PM
EJ1 wilcox's Avatar
Default Re: (RC000E)
Post pics!
That would be a pretty major mistake to make.
Old Oct 20, 2007 | 06:30 PM
SOHC_MShue's Avatar
Default Re: (EJ1 wilcox)
i'd post pics, but i dont have any batteries for my camera . I'll try pulling the bolts out and getting them apart. You can see where the line started, but it only looks like its barely there. It doesn't look like it goes all the way around.
Old Oct 20, 2007 | 06:44 PM
batboyvaj's Avatar
THE MORE METAL THE STRONGER THE ROD!!! DUH!
Old Oct 20, 2007 | 07:00 PM
Bailhatch's Avatar
Default Re: (batboyvaj)
if it has a line at all it has to be cut already. It's pretty hard to make a cut with 0 kerf half way through something.
Old Oct 20, 2007 | 07:02 PM
redzcstandardhatch's Avatar
something different
i'll bet my turbo on you being wrong. good luck!
Old Oct 21, 2007 | 04:51 AM
DaveF's Avatar
Default Re: (redzcstandardhatch)
in for the mayhem !!
Old Oct 21, 2007 | 05:49 AM
stealthmode62's Avatar
Default Re: (DaveF)
I don't think I'm jumping the gun at all when I say.
DEE-DE-DEEE
Old Oct 21, 2007 | 02:39 PM
SOHC_MShue's Avatar
Default Re: (stealthmode62)
alright you guys were right. They were cut, but i had 3 other people look at them and say they didn't look like they were . Although for some reason the arp bolts that came with the rods were on there super tight. We had to use an impact to get them off and they didn't come off without using a pretty good amount of force from the impact. One of the bolts came out stripped on one of the rods
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> I don't think I'm jumping the gun at all when I say.
DEE-DE-DEEE
thats messed up
Old Oct 21, 2007 | 02:50 PM
DaveF's Avatar
Default Re: (SOHC_MShue)
is just the bolt stripped or did it bring some of the rod with it ?
Old Oct 21, 2007 | 02:58 PM
SOHC_MShue's Avatar
Default Re: (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">is just the bolt stripped or did it bring some of the rod with it ? </TD></TR></TABLE>
as far as i can tell just the bolt, but i'll need to run a tap into the rod to clean it out. I'm sure some of the bolt threads are still in there. We couldn't get one of the good bolts to thread back in smoothly so i didn't even try using force on it.
Old Oct 21, 2007 | 03:12 PM
OMG B16's Avatar
p.s. The only reason i knew this is because back in the day i thought the same thing when i got my eagles. LOL.
Old Oct 21, 2007 | 03:21 PM
.CUBISH.'s Avatar
Default Re: (OMG B16)
wow..i hope youre not trying to build your own motor.....
Old Oct 21, 2007 | 03:31 PM
baynedo's Avatar
Default Re: (.CUBISH.)
acually the other day when we were looking at matts rods, I said it didnt look like they was cut just to mess with him.then i had him look where the rod was honed and he didnt catch that honing prosses would get rid of that line. But i was just making him paranoid. thats how we do.......
Old Oct 21, 2007 | 04:02 PM
90dxhmt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">wow..i hope youre not trying to build your own motor.....</TD></TR></TABLE>
Lol.Well at least he made a thread to trash a company though
