jdm b16a1 vtec solenoid gasket
Old Jun 20, 2002 | 08:08 PM
91HATCH's Avatar
Default jdm b16a1 vtec solenoid gasket
i was wondering wat you guys use for the jdm b16a1 vtec solenoid gasket?
Old Jun 20, 2002 | 10:17 PM
r7's Avatar
r7
Default Re: jdm b16a1 vtec solenoid gasket (91HATCH)
isn't there just an o-ring ?
i duno, my fuken solenoid is fuked, vtec only engages in first gear.. know anything about that ?
Old Jun 21, 2002 | 12:20 AM
coasterlvr's Avatar
I used a Del Sol gasket for the on that goes against the head. I also used a Del Sol for the smaller gasket on the actual solenoid. That one was not a perfect fit but works fine.
Old Jun 21, 2002 | 05:07 AM
SuperCivic's Avatar
i think the exact match is the one from the 99-00 Si..i know that has the same solenoid, but i believe the part numbers are the same for the del sol VTEC. go figure..either one should work.
Old Jun 21, 2002 | 07:20 AM
......'s Avatar
I tried to figure this out also about six months ago and tried them all. 99-00 si, del sol VTEC, 92-93 gsr and none of them are exactly the same. What I had to finally do was just HondaBond the hell out of it.
Old Jun 21, 2002 | 08:24 AM
SuperCivic's Avatar
Default Re: jdm b16a1 vtec solenoid gasket (......)
haha..i know what yer sayin. i ended up getting the solenoid off the del sol VTEC and just switching out the entire solenoid, then using the del sol gasket. go figure.
Old Jun 22, 2002 | 11:41 AM
Francois's Avatar
Yup,that's what I did.I use some Hondabond to stop the leak.
Before,I did tried to get the seal fit in it's groove by putting some books on the solenoïd on a table for a few hours.
When trying to put it on,the seal was looking ok.But after I started the engine,I saw a big leak.
The best way,it's to put silicone aroud the screen,then,there should be no problem.
I did 2 cars with mine and no leaks at all.
Old Jun 22, 2002 | 12:05 PM
marty's Avatar
any B series solenoid gasket. B18C1 - B18C5 - B17A1 - B16A3 - B16A2
Old Jun 24, 2002 | 11:11 AM
SiR831's Avatar
Default Re: jdm b16a1 vtec solenoid gasket (MugenEF7)
i think most dohc vtec solenoid gaskets (cylinder head) are the same. But the top gasket varies.
alexdog69
54
May 18, 2010 11:23 PM
ritchiedee123
13
Nov 2, 2009 01:30 AM
PsychoSiRex
Mar 3, 2004 03:20 PM
rathead
May 25, 2003 09:36 PM
Francois
Jul 10, 2002 05:06 AM
