new crx
Old Oct 19, 2007 | 09:27 PM
sfgsr1's Avatar
Default new crx
I just bought an 89 crx and have a few questions. I love the car its the first honda i have owned and i don't know much at all about it. I was wondering how can i tell which engine I have and what are some good parts to put onto it. I might do an engine swap down the road but I want something to do now until i can save up my funds. One last question, I am missing the trim piece that goes on the driver side window, does anyone know where to get a replacement? Everytime it rains i end up getting wet because of it.
Old Oct 19, 2007 | 09:41 PM
EFh@tCh24's Avatar
Default Re: new crx (sfgsr1)
u can tell what the motor is by looking at the stamp..if its an si crx u should have a 1.6 motor if u have a hf it should be a 1.5 motor
Old Oct 20, 2007 | 08:28 AM
SIred91's Avatar
Rainman
Default Re: (Dustin_Pierce)
You can get the garnish from the dealer. Its about 30 bux. Comes with all the clips and everything you will need.
Old Oct 20, 2007 | 12:42 PM
sfgsr1's Avatar
thanks for all the help, I changed the spark plugs today and noticed that there was oil on the plugs what does this mean?
Old Oct 20, 2007 | 01:20 PM
90SICRX's Avatar
Default Re: (sfgsr1)
Could be a number of things but could be leaking valve cover gasket, you sure it is oil and not gas? Is it on all of them? It would be oil then.
Old Oct 20, 2007 | 02:31 PM
gursh d's Avatar
Default Re: new crx (EFh@tCh24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFh@tCh24 &raquo;</TD></TR><TR><TD CLASS="quote">u can tell what the motor is by looking at the stamp..if its an si crx u should have a 1.6 motor if u have a hf it should be a 1.5 motor</TD></TR></TABLE>
for example, a b20 motor:
Old Oct 21, 2007 | 12:44 PM
sfgsr1's Avatar
Default Re: new crx (gursh d)
There was alot of oil on 1,2 and, 4. There was just a little bit on spark plug 3. And where is the engine stamped for the model?
Old Oct 21, 2007 | 12:52 PM
CRX Toad's Avatar
Passenger side front of motor right where the transmission connect to the motor. Find the distributor and go straight down from there until you see something like looks like what was posted above. YOU HAVE TO LOOK FOR IT.
Old Oct 21, 2007 | 01:36 PM
denraweb's Avatar
Here, this might help a little. The dotted circle is to show that the stamp is behind the hose/radiator part.
Modified by denraweb at 2:51 PM 10/21/2007
Old Oct 21, 2007 | 09:20 PM
EFh@tCh24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfgsr1 &raquo;</TD></TR><TR><TD CLASS="quote">There was alot of oil on 1,2 and, 4. There was just a little bit on spark plug 3. And where is the engine stamped for the model? </TD></TR></TABLE>
u mite have to check ur gaskets u proble have a leak somewhere
redsi89
Jan 27, 2018 10:24 AM
codel529
Jun 21, 2015 06:01 PM
JDN169
Apr 9, 2008 09:22 PM
Fortunate One
10
Jan 17, 2008 05:39 AM
JDM_d15b_eg8
11
Jun 12, 2007 11:29 AM
