Turning the buzzer OFF
Old Oct 19, 2007 | 08:36 PM
tehondafrk's Avatar
Default Turning the buzzer OFF
Hey all I need to know how I can shut the buzzer up in my '91 hatch that beeps for instance for a few seconds when you first start the car, or when you take your seatbelt off while the car is on. Mine has messed up and will NOT stop beeping lol and its driving me crazier than I already am. I've looked at both fuse locations that I know of (under steering column and under-hood) and have found nothing in either place about the buzzer. Anybody know how to shut it up?
There's not an actual problem that i'm aware of that would be causing it to stay on, I have replaced the driver's side door a couple days ago with one from a salvageyard but I took the panel off and everything looked fine in there, nice & clean from what I could see. The little harness that plugs into the door fits snugly.
Old Oct 19, 2007 | 08:51 PM
hondasaurusrex's Avatar
Default Re: Turning the buzzer OFF (tehondafrk)
id like to know as well...mine has a thing about staying on for a while sometimes..like minutes...
Old Oct 20, 2007 | 08:47 AM
tehondafrk's Avatar
Default Re: Turning the buzzer OFF (hondasaurusrex)
bump
Old Oct 20, 2007 | 09:07 AM
DenzComp's Avatar
Rear view mirror.
Pop off the plastic cover on the underside and you'll see screws. Take them out and when taking the mirror down you should see the plug. Just unplug it and put the mirror back up.
I don't remember 100% how I did it, but it's up there.
Old Oct 20, 2007 | 09:15 AM
grog's Avatar
Default Re: (DenzComp)
also the ignition (where you stick your key) has a beeper on the under side of it. remove the plastic cover on the steering column, and look/ listen (while turning key) under the ignition. all you do is unplug it I believe.
Damn beeps
Old Oct 20, 2007 | 08:43 PM
tehondafrk's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">also the ignition (where you stick your key) has a beeper on the under side of it. remove the plastic cover on the steering column, and look/ listen (while turning key) under the ignition. all you do is unplug it I believe.
Damn beeps</TD></TR></TABLE>
Oh ok, I wasn't aware of that beeper, lol. I'll find that bitch!
[QUOTE=DenzComp]Rear view mirror.
I don't remember 100% how I did it, but it's up there. [/QUOTE
Yep I took that one off today, I just wish I could find out why its actually beeping!
Thanks fellas!
Old Jan 3, 2008 | 12:45 PM
foxjaeger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DenzComp &raquo;</TD></TR><TR><TD CLASS="quote">Rear view mirror.
I don't remember 100% how I did it, but it's up there. </TD></TR></TABLE>
ya, i had the same problem. and this stoped mine. there's a little plug in there for the seatbelt light, i just unpluged it and put everything back togather.
jason!
Old Jan 3, 2008 | 01:08 PM
Ermil's Avatar
Default Re: Turning the buzzer OFF (foxjaeger)
I just unplugged a little grey box behind my center console. Shut all the seatbelt crap off.
Old Jan 3, 2008 | 01:15 PM
jakscivic's Avatar
My gfs car had the same problem. You just need to unplug it from the rear view mirror mount.
Old Feb 26, 2008 | 07:28 PM
gee510's Avatar
OK SO I FOLLOWED THE INSTRUCTIONS AND THE ANNOYING BUZZER IS UN-PLUGED FROM THE REAR VIEW MIRROR. NOW IN MY SITUATION THE DAM BUZZER AND LIGHT/SEAT BELT WAS GOING OFF WHEN EVER I WAS DRIVING AND APPLIED THE BRAKE. THE DASH LIGHT FOR THE DOOR/SEAT BELT IS STILL ON WHAT CAN I DO ABOUT THAT. OR WHY DO YOU FELLAS THINK COULD BE TRIGERING THAT DASH LIGHT.
Old Feb 26, 2008 | 08:35 PM
tehondafrk's Avatar
Default Re: Turning the buzzer OFF (gee510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gee510 &raquo;</TD></TR><TR><TD CLASS="quote">OK SO I FOLLOWED THE INSTRUCTIONS AND THE ANNOYING BUZZER IS UN-PLUGED FROM THE REAR VIEW MIRROR. NOW IN MY SITUATION THE DAM BUZZER AND LIGHT/SEAT BELT WAS GOING OFF WHEN EVER I WAS DRIVING AND APPLIED THE BRAKE. THE DASH LIGHT FOR THE DOOR/SEAT BELT IS STILL ON WHAT CAN I DO ABOUT THAT. OR WHY DO YOU FELLAS THINK COULD BE TRIGERING THAT DASH LIGHT.</TD></TR></TABLE>
Lol I took the ghetto way out and took the actual bulb out that makes that light blink....I don't know if I could get it back in now, its in a tight spot, but I fixed it at least!
Old Feb 26, 2008 | 08:41 PM
gee510's Avatar
LOL. I THOUGHT ABOUT THAT, IM JUST GONNA GIVE IT A COUPLE MORE DAYS IF CANT FIURE IT OUT I GUESS I'LL HAVE TO DO THAT. THANX THO
Old Feb 26, 2008 | 09:33 PM
tehondafrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gee510 &raquo;</TD></TR><TR><TD CLASS="quote">LOL. I THOUGHT ABOUT THAT, IM JUST GONNA GIVE IT A COUPLE MORE DAYS IF CANT FIURE IT OUT I GUESS I'LL HAVE TO DO THAT. THANX THO </TD></TR></TABLE>
Not a problem, good luck!
Old Feb 26, 2008 | 10:59 PM
rohderacer's Avatar
Had that same problem. What the others said you can remove the center console and locate the box that controls all that seatbelt **** and just unplug the harness and no more beeping. Lol i was ready to punch a hole throw my dash when that happend to me, its the most annoying beeping ever!!
91civiclx
Apr 10, 2009 10:00 PM
89hatcher
Mar 10, 2009 04:47 PM
black0hatch
Jul 31, 2007 03:28 PM
djbrandonr
Audio / Security / Video
Jul 16, 2006 08:01 AM
Steve90HB
20
Sep 4, 2003 11:14 AM
