Chattanooga Area F.S. 1990 Civic Hatch OBD1 Hondata LS Vtec Turbocharged
Old Oct 19, 2007 | 04:24 PM
2phast's Avatar
Default Chattanooga Area F.S. 1990 Civic Hatch OBD1 Hondata LS Vtec Turbocharged
This is going to make me sicker than I already am but I have no choice and must sell. I have $30,000 and hundreds of hours in this car. It only has 25 miles on it.
I bought this Civic 5 years ago and spent 3 years building it. 2 years ago I finished it and took it to Knowledge Performance in Atlanta for the initial startup and dyno. On it first pull with a generic tune and pump gas it pulled 191.1 Ft. lbs
of torque @ 4717 RPM and 188.5 WHP @6327 RPM this all at 6lbs of boost.
I trailered it back home. I took my Nephew on a 25 mile spin and put it up because it wasn't registered or insured yet and the rear wheels were rubbing in the corners. It is scarey fast. I put it in the garage and it has been there for the last 2 years. About a year ago I went out to start it up and all I got was a click and
it wouldn't start. I walked away and it is still sitting there. Battery is almost dead
but its a red top and will charge right back up.
I have a serious medical problem and I have to sell.
I have a firm price of $5000
You Can email me at Ralps@comcast.net for more pics or a phone #
Here is the build sht. (there is more than listed and everything is new
from the urethane bushings to the new windshield)
1990 Civic Hatchback Dx
Motor:
Bottom End: B18b1
Mods:
Posted Block with block guard
Line honed with a Z10 Block Girdle
Bored and Honed 1/2mm over
Decked block 0.008"
Wiseco 8.5 Coated Pistons
Eagle Rods / Arp Rod bolts
Clevite Bearings (all oil clearances 0.0010-0.0012)
Lightened Pulley (Type N)
8.5 lb ACT flywheel / 6 puck extreme with HD pressure plt.
Complete rotating assembly balanced as one unit.
New Oil Pump, Water pump, Tensioner, Gsr Timing Belt (all OEM)
Hasport Mounts
Head:
Top end: 1992 JDM B16a head
Mods:
Lightly ported (44.5 cc)
Stainless Valves 1 mm over
Titanium retainers
Upgraded dual springs
Bronze guides
(Valve components by KMS)
Head cross milled 0.006"
Prelude Lost motion assemblies
1996 GSR Cams
Skunk 2 Cam Gears
LS/Vtec Cometic Head Gasket
GSR Distributor
Turbo:
Turbonetics T3-04E 50 trim, .48 stage 2 exhaust (47lb/hr.)
Inline Pro T4 stainless manifold with custom adapter plate.
Tial 38mm Wastegate (10lb spring)
Blitz BOV (Not New)
2.5" SS down pipe
2.5" SS Cat back, with High flow Cat.
3 bar GM map sensor
Intake:
Type R Intake
Throttle body honed 2mm over
750 cc RC saturated injectors
Aftermarket fuel rail
B&M fuel pressure upgrade
Walbro HP pump in tank.
Wiring/ Elec.:
Dx conversion harness,
OBD0 to OBD1 conversion
Relocated Battery to rear with Disconnect switch
Hondata S200b
Hondata Chipped P28 ECU
Upgraded to elec. VSS
Cluster conversion
Suspension and Brakes:
Z-10 front crossmember
Eibach springs
KYB shocks
Suspension Tech rear sway bar
Teg Type R front sway bar (Not New)
EX front brake conversion to larger rotors.
Integra rear brake conversion to disks
Brembo Drilled and slotted rotors
Stainless Braided Lines
1" Master cylinder with 40/40 proportion valve conversion.
17" Axis 4 spoke wheels
Transmission:
YS1 cable
Hasport Linkage
Neuspeed short shifter
Momo ****
Misc:
Aluminum Racing Radiator, 92 conversion
Slim Fan
Roll cage
Hunsaker Racing Seats
5 point OBX Racing Harnesses
Momo removable steering wheel
Autometer Water, Elec, A/F, Oil Presure, Boost gauge.
Urethane Body kit by Wings West.
JDM Markers (Not New)
Custom Lights
[IMG]
[/IMG]
Modified by 2phast at 3:11 AM 10/20/2007
Modified by 2phast at 8:59 PM 10/20/2007
Old Oct 19, 2007 | 06:14 PM
2phast's Avatar
Default Re: Chattanooga Area F.S. 1990 Civic Hatch OBD1 Hondata LS Vtec Turbocharged (2phast)
Bump
Old Oct 21, 2007 | 08:10 PM
2phast's Avatar
bump
Old Oct 26, 2007 | 02:23 PM
2phast's Avatar
bump
Old Oct 27, 2007 | 03:27 PM
2phast's Avatar
bump
Old Oct 30, 2007 | 07:59 PM
2phast's Avatar
bump
eriki
Apr 6, 2013 10:53 PM
p3t3rxp4n
Jun 7, 2012 11:53 PM
2phast
Nov 10, 2007 09:32 PM
Pnoyej6
Feb 9, 2007 09:35 PM
Emshhh
Nov 6, 2006 02:19 PM
