90 accord getting poor gas mileage!!
Old Oct 19, 2007 | 01:29 PM
alexsaccord's Avatar
Default 90 accord getting poor gas mileage!!
Im working on a 90 accord that is only getting 16 mpg. What and where would I look for a problem. The car has a new cap, wires and plugs. TIA
Old Oct 19, 2007 | 04:06 PM
DrZFiNeSt's Avatar
Default Re: 90 accord getting poor gas mileage!! (alexsaccord)
Try putting in a new fuel filter and clean out the EGR valve.Is it throwing any codes?
Old Oct 20, 2007 | 07:29 AM
95GSRHONDA's Avatar
Also try puttin fuel injector cleaner in da tank afta changin da fuel filter
Old Oct 20, 2007 | 07:47 AM
Wiggler's Avatar
Also try changing the Oxygen sensor... that's probably going to help a lot...
Old Oct 20, 2007 | 03:23 PM
agno's Avatar
Do a general tune up. Replace fuel filter. Use quality fuel
Replace oil filter, use quality filter.
Make sure no leaks on intake. You could be running rich
Old Oct 20, 2007 | 07:02 PM
flight50's Avatar
Default Re: 90 accord getting poor gas mileage!! (agno)
there are a few threads on this from awhile back. check the archieves from alot more results. to many to list. but as you car gets older, expect is performance to go down a little. but 16mpg is pretty low for an accord old or not.
ferreiae
Nov 13, 2018 03:33 PM
KDoGx504
Sep 7, 2016 12:29 PM
The Collin
Apr 1, 2009 09:10 AM
dsettlemoir
Jun 13, 2008 07:58 AM
Orig
Jun 2, 2002 09:27 AM
