Tranny leak, after snap axle.
i snapped my axle, and i replaced it with a stock on, and they are the EXACT same i checked. i seem to be leaking from the passenger side axle shaft right from the tranny ?
it is in as far as i can get it. and it pops in and looks and feels great. can't figure this out. is there a seal that gets, old can falll out ?
1994 gsr
1994 gsr
there is a tranny axle seal that goes in btween the axle and tranny housing... check to see if it there. if not, buy and replace it, if it is, check for damage, which you'd have to replace anyway.......hope this helps.
is it rubber or like metalish.and does it go on the inside of the tranny ? kindof. cause somthing i did find something on my flood of the sort.
does the kasket stretch ? i don't know how to explain it really.
yeah, its like a rubber o-ring with metal bearings in side if i remember correctly. it goes inside the tranny, when you install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilpastrana »</TD></TR><TR><TD CLASS="quote">.
does the kasket stretch ? i don't know how to explain it really.</TD></TR></TABLE>
huh????
huh????
new_climber
Mar 27, 2008 05:05 AM
HellerDopeEK4
Feb 16, 2008 05:48 PM
Jonovision
Jan 4, 2006 04:04 PM
