help!!! b18b motor will not start after head swap.
Old Oct 19, 2007 | 10:52 AM
Ignitecivic's Avatar
Default help!!! b18b motor will not start after head swap.
i replace a new b18b head because the old one has a burnt valve. i replace the head gasket and intake manifold gasket and slap the head on.
the pistons were set TDC
cams were set at TDC
the dizzy arrow point at cylinder #1
i got sparks from the plugs
i got fuel cuz the spark plugs are wet
i check all the grounds, they're good
starter works
when i tried to start the car, the engine just turn and turn and turn. it feels like the car starts like a hybrid car.
could it be no compression on all the cylinders????
i need some help!!!!!
Old Oct 19, 2007 | 11:39 AM
fmrprojects's Avatar
Default Re: help!!! b18b motor will not start after head swap. (Ignitecivic)
do a compression and leak down test. do you know if your new head is good?
Old Oct 19, 2007 | 12:31 PM
Default Re: help!!! b18b motor will not start after head swap. (fmrprojects)
the head is pretty good. no leaks or anything. my previous head was all messed up with burnt valves and starts up and drive.
Old Oct 19, 2007 | 05:59 PM
doing compression test tonight
Old Oct 19, 2007 | 06:05 PM
BlackBeastEK's Avatar
did you put you spark plug wires in the right order pluged into the dizzy ? that could be your problem.
Old Oct 19, 2007 | 06:25 PM
dc2doi's Avatar
Check firing order, 1-3-4-2 from the bottom left on the dizzy.
Old Oct 19, 2007 | 06:47 PM
Default Re: (dc2doi)
yeah its
1 3
2 4
all i hear is whining of the starter
Old Oct 21, 2007 | 01:17 PM
Default Re: (Ignitecivic)
car is still dead
Old Oct 21, 2007 | 03:40 PM
DaYZeD.1's Avatar
is the starter even turning the motor? maybe it is not turning the flywheel... you said its just whining...
Old Oct 21, 2007 | 03:41 PM
DaYZeD.1's Avatar
make sure the head is torqued down right...
Old Oct 22, 2007 | 12:08 PM
Default Re: help!!! b18b motor will not start after head swap. (DaYZeD.1)
the starter is firing and turning cuz i took it out and test it.
the head is torque down to 65lbs
Old Oct 24, 2007 | 05:59 PM
i just put teh old head back, still no sign of starting up.
it keeps turning and turning
i used a diff dizzy, new plugs, new wires from a working car.
now im clueless
*working on this engine while the fire in san diego is going on too*.fuckkk
Modified by Ignitecivic at 9:55 PM 10/24/2007
Old Oct 24, 2007 | 06:06 PM
mustang5.slow's Avatar
* B A N N E D *
bump cause i hate when **** like this happens to me.
Old Oct 24, 2007 | 06:37 PM
P12 EG6's Avatar
Default Re: help!!! b18b motor will not start after head swap. (mustang5.slow)
ok first of all check to make sure the timing belt is on right. and then its gotta be the fuel system if the electrucal still works check ur fuel pressure .
Old Oct 24, 2007 | 07:37 PM
cooteg6's Avatar
Default Re: help!!! b18b motor will not start after head swap. (P12 EG6)
could be an electrical problem.check over the easy things first. don't waste your time taking that head on and off if you dont have to
Old Oct 24, 2007 | 08:58 PM
Default Re: help!!! b18b motor will not start after head swap. (cooteg6)
the weird thing is that i didnt even touch any electrical stuff when i replace teh head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cooteg6 &raquo;</TD></TR><TR><TD CLASS="quote">could be an electrical problem.check over the easy things first. don't waste your time taking that head on and off if you dont have to</TD></TR></TABLE>
too late i wasted 5 hrs
CD0419
Honda Civic (2001 - 2005)
Oct 21, 2017 09:23 PM
S_F
34
Nov 22, 2012 10:54 AM
dinthanonh
Oct 31, 2011 10:37 AM
blinger
Apr 14, 2007 03:24 PM
zeroek
10
Jul 30, 2006 09:27 AM
