lip question
ok so im about to order my si lip for my 00 sedan... all i wanted to know is which numbers on this pic do i need along with the lip to install as soon as its delivered as u can see the lip is already highlighted... what numbers do i need for the mounting hardware???
http://www.hondaautomotivepart...=null
are you asking what you need to install the lip kit?? if its just a lip, all you really need is about 8 screws (4 on front, 4 on back) but if you want it on super tight, try using some kind of trim adhesive on the backside of the lip kit then screw it on the wheel wells (on opposite side of mud flap on front, the side of mud flap on back). that should be all you really need. i dont think they have "lip installation bolts/screws and hardware". lol good luck.
actually if u looked at the picture they do have hardware for installation so it fits perfectly but i guess your right i can use pretty much any screws as long as i put them in the right place
They do have specialty hardware for lips, but I would recommend aftermarket since the OEM stuff can rust and turn to ****. Plus instead of having an $80 lip hardware kit, you might only spend $15.
http://inlinefour.com/oemhofrlipha.html <--inline four has a oem set of front lip hardware
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">here is a thought for you contact the dealer and find out if it comes with the mounting hardware. If not I am sure that they have a kit avil. </TD></TR></TABLE>
thank u very much thats the answer i was looking for thanks
I said it'd be expensive.
There is no kit from Honda US as far as I know. They have to piece it together (it's not just one part number - it's lots). It ends up very expensive.
It's worth your time to buy aftermarket. They hold up better and are cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghetto Civic HX »</TD></TR><TR><TD CLASS="quote">By the looks of the picture you'll need parts #35-#44 minus #38, which looks like it bolts to the bumper support.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">I said it'd be expensive.
It's worth your time to buy aftermarket. They hold up better and are cheaper.</TD></TR></TABLE>
agreed
agreed
rustyj84
24
Feb 5, 2004 08:36 PM
