ek b18c stock 13.59 0-60ft 2.09 ??
Old Oct 19, 2007 | 06:50 AM
EKBOOSTED's Avatar
Default ek b18c stock 13.59 0-60ft 2.09 ??
recently at dragway napierville i run 13.59@102 mph with semi slick 22x815
stock ek hatch 96 with heavy weight 5 bolts type-r conversion brake
b18c type-r 96 with 4.40 lsd bone stock
short ram 3"
headers 4-1 jasma
walbro 255lp
p28 chiped with chrome
semi slick 22x8x15
it is normal for stock type-r to run 13.59 ?? i think have some special in internally
Old Oct 19, 2007 | 06:54 AM
JKov240's Avatar
Default Re: ek b18c stock 13.59 0-60ft 2.09 ?? (EGBBOOSTED)
Most B-Series swapped cars run low 14's to high 14's (depending on driver, traction, etc. and most are on street tires).
I could see you running a 13.5...you have a pretty damn good 60ft time (LSD and slicks) and your trap speed matches up with it. But I'm sure people will still ask to see a time slip.
How much does your car weigh?
slo_hatch's Avatar
actually that sounds ABOUT right......a type r runs maybe a 14.5 or 14.8 somethin around there on stock ecu. since yours is chipped and you have bolt ons and the lsd, not to mention a hell of a lighter car than a teg type-r. so your runnin right around where you should be im pretty sure. someone correct me if im wrong. thats a hell of a time for stock n/a tho.
Old Oct 19, 2007 | 06:57 AM
Luserkid's Avatar
Sounds right with slicks as most people get high 13/low 14s with type R motors on street tires (we did)
Old Oct 19, 2007 | 07:00 AM
charlieboyhonda's Avatar
great timing man you got a pretty good combination in that ek. I have seen b18c turbos doing that time and yours is n/a so keep it up
Old Oct 19, 2007 | 07:01 AM
HarfordCTR's Avatar
Default Re: ek b18c stock 13.59 0-60ft 2.09 ?? (Luserkid)
My Type-R in my EG hatch goes mid to low 13's consistently. It isn't totally stock though. But that is normal for that motor, and a good driver.
Old Oct 19, 2007 | 07:51 AM
vlc92189's Avatar
Default Re: ek b18c stock 13.59 0-60ft 2.09 ?? (HarfordCTR)
my buddy of mine ran 13.5 with slicks with his stock type r in his eg hatch. gutted though.
Old Oct 19, 2007 | 02:27 PM
EKBOOSTED's Avatar
i think with better slick like M/T ET 22x8x15 im probaly running 13 low
Old Oct 19, 2007 | 05:45 PM
nemesiskrp's Avatar
Default Re: (EKBOOSTED)
i dont understand, a type r motor has like 195 hp around there i think and a b16 has 160 i think.... how does a type r gain 1.5 sec faster on the 1/4 mile over the b16 in a ek with a +35 est hp....????
Old Oct 19, 2007 | 05:53 PM
nemesiskrp's Avatar
Default Re: (nemesiskrp)
i mean wouldnt u think a average b16 with basic mods in a ek or eg would run around 15 in the 1/4....
Old Oct 19, 2007 | 05:58 PM
EJ1chevelle's Avatar
Default Re: ek b18c stock 13.59 0-60ft 2.09 ?? (EKBOOSTED)
not saying i dont beleive you but can we see time slips?? that is some quickness i havta see. good times bro.
Old Oct 20, 2007 | 05:27 AM
JKov240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesiskrp &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand, a type r motor has like 195 hp around there i think and a b16 has 160 i think.... how does a type r gain 1.5 sec faster on the 1/4 mile over the b16 in a ek with a +35 est hp....????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesiskrp &raquo;</TD></TR><TR><TD CLASS="quote">i mean wouldnt u think a average b16 with basic mods in a ek or eg would run around 15 in the 1/4....</TD></TR></TABLE>
Most B16'd hatchbacks I've seen run mid 14's-low 15's.
The things that you're not looking at are...
1) B16 transmissions don't have a limited slip differential, Type-R's do
2) B16's are known as the "torqueless wonder"...Type-R's have 20+ lbs/ft of torque more than a B16
3) #2 was comparing a STOCK B16 to a STOCK Type-R
His car isn't stock...he has the basic bolt-on's and a tune on it which does make the car run better (I got my B18C1 tuned with my basic bolt-on's and low comp. pistons and noticed a difference )
4) Did you notice his 60' time? A 2.09 is pretty damn good...which brings me to the point of #4 and back to #1, he has a LSD and on top of that, drag slicks.
That's how his Type-R powered EK is faster than a B16 EK
Old Oct 20, 2007 | 11:07 AM
nemesiskrp's Avatar
Default Re: (JKov240)
hey you said b16s are the torqueless wonder..... now if you boosted a stock b16 at 10 lbs would it still be considered that name? jw
Old Oct 20, 2007 | 01:41 PM
JKov240's Avatar
Alot of other things have to be considered other than the boost you're running...the tune, for example.
But to answer your question, when you put a turbo kit on any small displacement motor, there is a pretty big gain in torque.
Old Oct 20, 2007 | 01:47 PM
Ex-Eg-Driver's Avatar
you are the chosen one...
97blacklude
Aug 14, 2008 11:22 PM
JBk24crx
Jun 16, 2004 12:53 PM
macrosshn
Jul 4, 2003 10:13 AM
