shorter head studs on a y8??!!
Old Jun 20, 2002 | 06:26 PM
ShiroX's Avatar
Default shorter head studs on a y8??!!
I already have a mini me swap done but had a head gasket issue so I decided to change it...
I used z6 head studs before but now i decided to by y8 because its cheapers plus thats the head i am using so i figured what the heck....
i just got the head studs and they dont look anything like the z6 heaad studs and theyre 20mm or so shorter!!?
Is this right??
Old Jun 20, 2002 | 10:09 PM
the DR.'s Avatar
Default Re: shorter head studs on a y8??!! (VTeC4TheChildren)
theyre different, the y8 studs are alot shorter... this caused me problem, major problems, i dont know if it will cause you any, but i increased my compression way too much and stretched those head bolts out seriously, and stripped the block in the process, im me if you have any questions on what not to do lol..
Old Jun 21, 2002 | 03:24 AM
ShiroX's Avatar
Default Re: shorter head studs on a y8??!! (CIVICtypeS)
what application did you use the y8 studs on?
tampabitches
Nov 29, 2008 06:06 AM
socialburn0035
Jul 24, 2008 03:14 PM
CptMidway
Aug 4, 2005 06:46 AM
didyouhearthat
13
Sep 24, 2003 09:18 PM
