itbs on internally stock GS-R
Old Oct 18, 2007 | 10:13 PM
Ra GS-R's Avatar
Default itbs on internally stock GS-R
would it be very gainful to go with itb's over upgrade Itake Manny, Throttle Body, and intake on an internally stock gsr w/header, test pipe, and exhaust or should i wait till i replace w/ctr pistons, cams, valve train?
Old Oct 18, 2007 | 10:18 PM
Dartanian's Avatar
Default Re: itbs on internally stock GS-R (Ra GS-R)
ITB's need to be tuned. You won't make enough power to justify the cost of having it properly tuned.
Old Oct 19, 2007 | 12:44 AM
LastDetail's Avatar
Default Re: itbs on internally stock GS-R (Dartanian)
Yeah I don't reall think that with a stock GSR you are going to need that much air into the head. Course, I could be wrong.
Old Oct 20, 2007 | 01:18 PM
CeReal's Avatar
Default Re: itbs on internally stock GS-R (LastDetail)
or under daily driving are itbs efficient?
Old Oct 20, 2007 | 02:24 PM
E.J.'s Avatar
わたしは。。。
Default Re: itbs on internally stock GS-R (CeReal)
To answer in short NO.
ITBS usually make the most power on built motors. They work well with motors with high CR and aggressive cams.
Old Oct 20, 2007 | 02:35 PM
yc_dc4mar's Avatar
Default Re: itbs on internally stock GS-R (E.J.)
itbs are not a good way to go with stock gsr. you wont make that much power and its not worth the money. go turbo. you will make more power that way. if you fully built it, then yeah itbs are awesome. but not on stock.
Old Oct 20, 2007 | 02:57 PM
iluvmydc4's Avatar
waste of money if your motor isn't built IMO
DelSolMike
21
May 15, 2014 04:50 PM
boosted91crx
Aug 1, 2011 01:00 PM
classdork987654
Jan 31, 2010 09:13 AM
AnthraxVX
Aug 24, 2006 10:05 AM
dunkd
Apr 20, 2005 09:16 PM
