Ls/vtec in delsol w/cable tranny. Which Axles?
Old Oct 18, 2007 | 08:47 PM
1 Fly SI's Avatar
Default Ls/vtec in delsol w/cable tranny. Which Axles?
We are putting a ls/vtec out of a Da (cable tranny)in my buddies Delsol. I can't find any info on it. Which axles do I need? Will the Da axles work?
Old Oct 19, 2007 | 04:29 AM
1 Fly SI's Avatar
Default Re: Ls/vtec in delsol w/cable tranny. Which Axles? (1 Fly SI)
ttt
Old Oct 19, 2007 | 04:48 AM
nix94delsol's Avatar
same as doing ANY b series swap
Old Nov 10, 2007 | 03:11 PM
MrMug3n's Avatar
id hope by now you would have figrd it out and you have the car running but use the integra b series axles out of a 91-93 but you are going to haft to get the half shaf as well. the newer axels wont work if you pulled this motor and are using the 93 shaft. good luck
Old Nov 10, 2007 | 03:45 PM
USDMCIVICHATCH's Avatar
Default Re: Ls/vtec in delsol w/cable tranny. Which Axles? (MrMug3n)
so you want to trade you're b16 tranny for a Ls? if so I have a good 99 ls tranny
Old Nov 10, 2007 | 04:25 PM
prettylew's Avatar
why would u go thru the trouble of converting your hydraulic clutch to cable in your delsol???????
Old Nov 10, 2007 | 04:28 PM
b16a3delsol's Avatar
ditch that cable tranny and get a hydraulic one right now!!
Old Nov 10, 2007 | 05:21 PM
1 Fly SI's Avatar
Default Re: (prettylew)
I pulled a whole swap out of my buddies wrecked Da. It isn't running yet beacuse JHPUSA sucks *****. I ordered the conversion three weeks ago and still no conversion. Well it is ok because I tucked it and made a tuck harness for the motor also. Custom brake lines and new paint on the motor and in the bay. Hopefully monday the mount will come.
The reason I am running hydro is because it came on the motor and I have three extras laying around. Also it has been really hard lately finding hydro trannys local.
The car isn't mine, I am doing this for a friend so I do what ever he wants to.
Racko
Transmission & Drivetrain
Jan 19, 2009 04:57 PM
baysic r
Dec 21, 2008 03:35 PM
LS94tegra
Feb 25, 2008 09:08 AM
IntegraG2
Dec 21, 2007 10:51 PM
Lethalb18c1
Dec 30, 2006 07:35 PM
