where is the main relay located?
on a 90 dx crx where is the MAIN RELAY located? my car wont start and the fuel pump works but the injectors arent spraying any fuel, so this guy told me my main relay should click and if so how many times should it click?
thanks alot that helped 1 more question? is it possible for this to be bad and let my fuel pump work but not let the injectors to work? and do u have any idea how many times this is suppost to click some1 said something about it earlier but never explained or elaborated!
if your fuel pump is working then the relay is good, you said the injectors arent spraying....... huh maybe check the fuel pressure regulator maybe that is clogged are the injectors even getting power.....
i have good fuel pressure but the injectors are not firing. the wires that comes from the reistor box that goes to the injectors has juice when trying to crank. the wires that goes to the ecu has no juice when trying to crank? the car was runing but through cel 16 and the cut off and hasnt crunk back since. the ecu and resistor box is fine bc i tried them in another car and ive alseo swapped dizzys.
is the ecu getting power......... might be a blown fuse i am stumpped to be honest... check under the hood there is a fuse for the ecu. replace it even if it dont look bad might have a short.
95turboeg
11
Jun 13, 2013 03:51 PM
tundra2000
Jun 9, 2010 06:33 PM
