do u really need valve stems on new tires/wheels?
Old Oct 18, 2007 | 07:08 PM
ShinotakuX's Avatar
Default do u really need valve stems on new tires/wheels?
I'm about to purchase a set of DR17 with new tires, but they include the "valve stems", do I really need this or not? also, I can use my stock lug nuts right? thank you.
Old Oct 18, 2007 | 07:31 PM
SPD DMN's Avatar
Default Re: do u really need valve stems on new tires/wheels? (ShinotakuX)
Are you asking if you need valve stems in general, or are you asking if you need to use their valve stems? Yes you need valve stems in general (duh), but as far as using the ones including, you don't have to... but might as well use the new ones they give you incase yours has a leak, or its worn etc.
Never use OEM lug nuts on aftermarket wheels. OEM lug nuts are ball seat shaped to fit OEM steelies, which mate with the ball seat lugs. Aftermarket wheels are acorn or tapered seat, so you need aftermarket lugs with acorn/tapered seats
Make sure you torque them to spec as well
Good luck!
Zidane6894
Feb 6, 2012 08:05 AM
ef_dx_90
Oct 1, 2011 12:13 PM
1ls/vtec
Dec 5, 2009 08:40 PM
HORNYGOLDFISH
Jan 23, 2009 09:13 PM
akkord94
Dec 12, 2006 03:49 PM
