whats better, ABS plastic lip or Polyurethane lip?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dustin_Pierce »</TD></TR><TR><TD CLASS="quote">Polyurethane by eventually it'll crack from previous bump scratches and so on. You would then have to use bondo to fix it. Good luck man.</TD></TR></TABLE>
go with poly. ive heard that ABS has crappy fitment and they crack alot easier.
I believe all OEM lips, civics and integras came in ABS plastic.
The [abs plastic]lips that are sold in ebay are generally just replicas so they have horrible fitments.
Polyurethane are usually a but stronger due to the fact that poly replica lips are thicker, so they have more flex without cracking.
I would not recommend fiberglass because they are prone to cracking quickly even with minimal force. A friend of mine has gone through 2 sets of fiberglass fenders for his s2k, [ im sure that fiberglass lips are just as frail] he has now decided to go back to OEM.
cool. thanks for the fast replies. i just bought a type r lip off a vendor from ebay, originally it was supposed to be ABS plastic , but he ran out and offered to give me the polyurethane lip for same cost. i just hope it looks and fits ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.J. »</TD></TR><TR><TD CLASS="quote">I believe all OEM lips, civics and integras came in ABS plastic.
I would not recommend fiberglass because they are prone to cracking quickly even with minimal force. A friend of mine has gone through 2 sets of fiberglass fenders for his s2k, [ im sure that fiberglass lips are just as frail] he has now decided to go back to OEM.</TD></TR></TABLE>
not true, all oem lips are polyurethane
http://www.jdmshit.com/parts/exterior/98ITRPu/
I don't think ABS could do this.
Go with Polyurethane!
trust ABS is ****. i had a cheap ABS lip and it broke off on the freeway. but i had a poly mugen replica lip and it bends WAY better. it does eventually crack but that shouldnt be a problem if your carful. my mugen one was just too low to the ground so i hit every small dip and it would just kill it :[.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BinMop »</TD></TR><TR><TD CLASS="quote">
not true, all oem lips are polyurethane</TD></TR></TABLE>
nice to know, cause I wasn't too sure. Thought I read it somewhere that they were ABS
Poly is the best and I'm almost positive it's what all OEM lips are made of. After that I'd take ABS plastic but it's easier to crack and doesn't always fit very well (that might just be because of crappy design). Fiberglass is way too easy to crack for me to ever even consider it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4R27 »</TD></TR><TR><TD CLASS="quote">cool. thanks for the fast replies. i just bought a type r lip off a vendor from ebay, originally it was supposed to be ABS plastic , but he ran out and offered to give me the polyurethane lip for same cost. i just hope it looks and fits ok</TD></TR></TABLE>
I hope you're getting the poly, my oem(poly) has been through a lot and still no serious damage(knock on wood) just scratches.
OEM is KING, but if not available then i go POLY. Check jdmshit.com for list, and options. Good place, and good guys.
