This seems like to much
just testing waters i askd a local shop to give me a quote for a
full k20a swap out of a 08 CTR ...... including EVERYTHING
they want 12,100 obo
i know K-series are expensive but DAMN
Description Qty Cost Total
Hasport Mount Kit EKK1 550.00T
K20A Type R Complete JDM Swap 1 5,600.00T
Ship Motor 250.00T
Karcepts Shifter Box 150.00T
Hybrid Racing Conversion Harness 335.00T
DC Sport Swap Header 375.00T
Swap Axles 300.00T
AEM Swap Intake 250.00T
Serpintine Belt 19.00T
Hondata K-Pro 850.00T
Shipping ECU to Hondata and Shipping Back 70.00T
SloMo K-Series Fuel Rail 125.00T
SloMo Fuel Filter and Bracket 100.00T
SloMo Custom Stainless Steel Clutch Line 100.00T
OEM Throttle Cable 35.00T
EP3 Idler Pulley Kit 120.00T
OEM Shifter Washers 20.00T
Upper and Lower Radiator Hose 40.00T
OEM Fan Switch and Coolant Temp Sensor 80.00T
Modify Coolant Neck for Switch and Sensor 70.00T
Oil, Oil Filter, Coolant, Tranny Fluid 50.00T
Misc Shop Supplies and Used Fluid Reclaim Fee 25.00T
Remove Current Motor 350.00T
Modify Passangerside Mount for New Hasport Mount 90.00T
Remove P/S and A/C 210.00T
Wire Conversion Harness and Fuse Box 245.00T
Modify Shifter Hole and Mount Shifter Box 90.00T
Install Throttle Cable 35.00T
Install K-Series Motor 420.00T
Install Header and Intake140.00T
Hondata K-Pro Tuinng Package 500.00T
Tuning Package Discount for Installation of Motor Swap -250.00
$12,109.72
Ship Motor 250.00T
Swap Axles 300.00T
$12,109.72
so tell me this.. why do you need an aftermarket shifter box, aftermarket axles, hondata (unless you are gonna boost or something), aftermarket fuel rail, aftermarket fuel filter and bracket, aftermarket clutch lines, a pully kit??
why dont you remove the ac and power steering yourself.
why cant you install the header and intake?
no hondata no tune needed.
so with all that removed your looking at a lot less.
just curious as to why you need the aftermarket ****. i mean 100 bucks for a fuel filter? WTF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">so are we to believe after the headache you put us through with your h22 that you have 12 grand stashed away for this swap?
curious what headache did he put you through?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard... »</TD></TR><TR><TD CLASS="quote">
curious what headache did he put you through?</TD></TR></TABLE>
Countless numbers of threads each day. Problem after problem *shakes head*. I refused to join in on them, but they were an eyesore
sounds like the OP needs to learn how to research his problems and think for himself instead of asking for everyone to do the work for him. if he has 12k stashed for this swap, then he should not have to be on here posting problem after problem cause he can pay for it to be fixed yes?
The whole deal looks very reasonable. I certainly wouldn't do it any cheaper.
You could save a few bucks if you cut corners, but why? Do it right the first time.
Or you could do it yourself and save on all the labor costs.
seems reasonable to me, especially considering that's basically a brand new motor being that it's out of an 08...deffinetely some stuff you could save money on from that list but considering the work involved that is pretty fair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">joined the military
22g bonus
REALLY bad way to spend your bonus. Trust me. I've seen this so many times before. Guys from the DAFB would get their bonus and buy an Evo and then not be able to afford furniture even. Save the money or spend it one something more reliable at least.
22g bonus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">I thought there were issues with installing the brand new K-series (8th gens) into our cars. Something about DBW or something.</TD></TR></TABLE>
Finally, someone mentioned the Drive By Wire problem present in swapping these K20s in the older cars.
EDIT: Man, don't waste your money on a K20. Hold onto it, begin to structure yourself a life, and enjoy the god-damn H22 that you spent so many freakin hours getting back into order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">dbw? que</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">Finally, someone mentioned the Drive By Wire problem present in swapping these K20s in the older cars.
EDIT: Man, don't waste your money on a K20. Hold onto it, begin to structure yourself a life, and enjoy the god-damn H22 that you spent so many freakin hours getting back into order. </TD></TR></TABLE>
Yeah, if the term Drive By Wire is foreign to you, I'd say don't get involved in it.
EDIT: No pun intended
(foreign. {nevermind})
Modified by BlackoutVTi at 10:45 PM 10/18/2007
(foreign. {nevermind})Modified by BlackoutVTi at 10:45 PM 10/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">Yeah, if the term Drive By Wire is foreign to you, I'd say don't get involved in it.</TD></TR></TABLE>
You'll be pissed if you waste it on a car you're probably not going to be into in a couple of years. Much less the possibility of a wreck or theft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lscivic1999 »</TD></TR><TR><TD CLASS="quote">with that kind of money just buy a K swapped car...there are a lot of them on the Marketplace..</TD></TR></TABLE>
And he'd still be blowing it all on something he'd probably later regret.
Seriously, this is a bad idea.
Much less spending it on someone else's project which might have any array of issues.
Much less spending it on someone else's project which might have any array of issues.</TD></TR></TABLE>
yea, defiantly no doubts..
Get a Type R if you want a nice/performance car that doesnt lose a lot of value, gotta make sure its secured...
