EK fuse block question!(gagues installation)
Old Oct 18, 2007 | 02:18 PM
enigma94's Avatar
Default EK fuse block question!(gagues installation)
Ok, I found the diagram for the fuse block, but still am not sure what numbers 1,3 and 4(the optional plugs not the actual fuses) are for. I'm installing my new Defi's and I know to use #2 for the illumination, but I still need a ground and ignition power.
TIA!
Old Oct 18, 2007 | 05:52 PM
enigma94's Avatar
Default Re: EK fuse block question!(gagues installation) (enigma94)
anybody?
Old Oct 18, 2007 | 08:43 PM
AdamB18C1EK's Avatar
im pretty sure i hooked my wideband up to the number 3 with the circle and you can ground your gauges to the bolt under the dash right beside your gauge cluster its a 10mm
KangBanger
Feb 2, 2010 01:03 AM
lowakkord
Jul 28, 2008 02:14 AM
gamakichi77
Jan 26, 2004 06:17 PM
white95
Apr 5, 2003 02:06 PM
