whats the worst that can happen if i dont get my rods machined after i put in arp rod bolts
Old Oct 18, 2007 | 12:07 PM
blackcrx16's Avatar
Default whats the worst that can happen if i dont get my rods machined after i put in arp rod bolts
whats the worst that can happen if i dont get my rods machined after i put in arp rod bolts?
and what exactly do they machine after the install of the arp rod bolts?
Old Oct 18, 2007 | 12:11 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: whats the worst that can happen if i dont get my rods machined after i put in arp rod bolts (bla
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcrx16 &raquo;</TD></TR><TR><TD CLASS="quote">whats the worst that can happen if i dont get my rods machined after i put in arp rod bolts?
the worst thing that happens is you die
Old Oct 18, 2007 | 12:48 PM
RX3's Avatar
RX3
The big end of the rod will be out of round and the motor will lock up. It cost about $60.00 dollars to have the rod sized.
Old Oct 18, 2007 | 03:31 PM
dohcMONSTER's Avatar
spin a bearing, throw a rod......
Old Oct 18, 2007 | 09:59 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
the worst thing that happens is you die</TD></TR></TABLE>
I wasn't aware that machining was necessary. As long as the bolts are stretched properly, they shouldn't cause any problems.
Old Nov 12, 2007 | 06:49 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RX3 &raquo;</TD></TR><TR><TD CLASS="quote">The big end of the rod will be out of round and the motor will lock up. It cost about $60.00 dollars to have the rod sized.</TD></TR></TABLE>Are you suggesting that he need to "Rebalance" the rods? If this is the case, it makes sense. Otherwise, what the new rod bolt does that will lock up the motor
Lsweez
Nov 28, 2007 04:03 PM
SiBuddy00
Feb 28, 2005 01:06 PM
turbohf
May 11, 2004 06:30 AM
egturbo
Feb 17, 2004 10:27 AM
Drag R
Jun 14, 2003 07:54 AM
