no power to air conditioning?
Old Oct 18, 2007 | 07:06 AM
prelude-all-the-way's Avatar
Default no power to air conditioning?
the air conditioning/heater does not turn on. It is not getting any power at all. Could this be a connector in the engine bay? any suggestions?
thanks Rob
Old Oct 18, 2007 | 07:38 AM
Dangger's Avatar
could be the climate control itself. it's a cold solder problem. take out your climate control and retouch all the soldering joints with an solder iron.
Old Oct 18, 2007 | 08:08 AM
lude98SH's Avatar
Default Re: (Dangger)
why would you go to the trouble of doing that ? Get a wiring diagram first before you go pulling stuff apart. With the symptoms of your problem you should be able to narrow it down.
Old Oct 18, 2007 | 08:37 AM
Default Re: (lude98SH)
could it be a fuse or some bad connection cause it worked before and now it doesnt even turn on?
Old Oct 18, 2007 | 08:44 AM
mgags7's Avatar
check all the fuses and check the connector that clips the one wire to the compressor.
Get a helms and a multimeter.
Old Oct 18, 2007 | 08:57 AM
Default Re: (mgags7)
I fixed it
it was fuse 9 15amp under the fuse fox
thanks anyway
Modified by prelude-all-the-way at 10:19 AM 10/18/2007
Evil Tom
Honda CR-V & Element
Aug 25, 2017 06:03 AM
maxent
Honda Civic (2006 - 2015)
Aug 22, 2017 10:05 AM
derekhannon
Jun 27, 2013 05:52 AM
JerseyJohnny
Apr 16, 2007 04:51 PM
