Will struts for a 96+ civic coupe fit my 95 gsr?
not the rear, the rear struts are thicker on a Integ. since the struts are made for a 6th gen Civic I believe it will be a bit too narrow to go on the lca.
that's correct...the fronts are cool but the bushing on the rear LCA is thinner on the 96 EX. You can put the GSR struts on an 96 civic but you need to use some washers to shim it.
VTEC_PRODUCTION
Nov 6, 2007 11:52 AM
