2000 civic si ebp 15,501 original miles top notch parts
ENGINE
portflow port and polish,valve job,polish chambers,open chambers to 84mm
supertech valves spring and retainer kit
benson sleeved 84mm
pauter rods
cp pistons
str fuel rail
str 70mm throttle body
str cam adj gears
(air) carbon fiber intake manifold
endyn breather kit
arp head studs
precision 1000cc peak and hold
hasport motor mounts
endyn bosch fuel pump
cometic head gasket
msd digital 6 plus 6520
msd ignition coil 8252
c&r full size radiator
fluidamper harmonic balancer (street)
hondata stage 3 W/boost
hondata obd I to obd II harness
hondata heatshield gasket
p28 ecu for hondata
magnecor wires (45232)
hyper ground grounding system
civic type r cams
oem Honda rebuild kit
optima yellow top battery
oem Honda red valve cover
quaife lsd
Jackson racing oil cooler
samco radiator hose kit (blue)
spoon oil filler cap, radiator cap,drain plug set
b&m fuel pressure gauge
spoon thermoswitch
spoon thermostat
spoon radiator brackets
tilton clutch w/ modified stock flywheel
tilton hydraulic release bearing,tilton 75 series m/c kit,tilton m/c adapter
thermal 3” exhaust
carsound hi flow cat
comptech intake system
kamikaze headers
clutch masters stage 3 clutch
stage 3 modified gator racing axles
EXTERIOR
oem fog lights
rear spoiler
blue tinted windows
racing hart cpo35 17” white w/toyo proxes fz4 tires
c-west eye lids for headlights (painted)
INTERIOR
civic type r carbon fiber bezel
jdm shift boot cover
piaa extreme bulbs
greddy 60mm warning gauges (silver) boost,air /fuel,oil pressure,fuel pressure
apexi rev speed meter
white dash gauge layover
spoon sports shift ****
SUSPENSION
koni fully adj coilovers
full race traction bars
spoon rear lower tie bar
spoon front lower rie bar
2000 civic si ebp 15,501 original miles always garaged, and only driven in nice weather bought brand new. I had earl from Honda-tech build the short block balanced and blueprinted and tom at port flow build the head. The parts on my list are either brand new or slightly used. car has not been licensed since 2002 and has been garaged since never really had time to put back together and just wanna get out of it. car is in immaculate condition no dents, scratches and the interior smells new still. the engine is completely disassembled, I have all original factory parts also. Want to sell car as is with all the
parts included
make offer
benson sleeved 84mm
pauter rods
cp pistons
str fuel rail
str cam adj gears
endyn breather kit
arp head studs
cometic head gasket
p28 ecu for hondata
civic type r cams
quaife lsd
spoon thermoswitch
spoon thermostat
thermal 3” exhaust
kamikaze headers
EXTERIOR
oem fog lights
rear spoiler
blue tinted windows
INTERIOR
piaa extreme bulbs
SUSPENSION
parts included
make offer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brisauce »</TD></TR><TR><TD CLASS="quote">wow,
it sounds very nice.</TD></TR></TABLE>
yes it does . wish i had the extra cash sitting around to throw down .. maybe if i sell my coupe .
it sounds very nice.</TD></TR></TABLE>yes it does . wish i had the extra cash sitting around to throw down .. maybe if i sell my coupe .
