cv shaft popped out. doh!!!!
Old Oct 17, 2007 | 08:03 PM
layedoutat0psi's Avatar
Default cv shaft popped out. doh!!!!
well i picked my buddy up from the bar the other day and i pulled up to a red light. there was a cop sittin at the other side goin across ways form me. i went to take off and nothing happend. he pulled over and helped me move the car to a parking lot. i checked everything over and found nothing. it was weird cause it didnt make no noises didnt feel anything at all. next day i jack up the car and i found out that the passangers side cv shaft had popped out of the tranny. has this happend to alot of people or did somethin just randomly happen to me??? oh by the way i have a jdm b16 swapped 91 crx
Old Oct 17, 2007 | 08:21 PM
UfoTofU's Avatar
Default Re: cv shaft popped out. doh!!!! (layedoutat0psi)
Tranny / motor mounts maybe?
Old Oct 17, 2007 | 08:23 PM
you think bad motor mounts would make the shaft come out?
Old Oct 17, 2007 | 08:39 PM
nihad's Avatar
I doubt it make sure they are the right length and that they have the round rings on the ends so they stay in there.
Old Oct 17, 2007 | 08:55 PM
UfoTofU's Avatar
I was just guessing. maybe the motor and tranny was shifting around a lot do to bad mounts?
Old Oct 18, 2007 | 06:48 AM
dxtosirex's Avatar
Default Re: cv shaft popped out. doh!!!! (UfoTofU)
I had this happen to my crx for years. I had a D16 motor and trans. I bought new axles from Advanced Auto Parts The passenger side kept popping out. I ended up putting the Dx axle back into the trans with now probs at all. I lined up both axles side by side, both looked the same. Must have been a cheap New POS axle! You better filler up with some trans fluid. I dident and lost a trans for that.
Old Oct 18, 2007 | 07:14 AM
Ti Rider's Avatar
Default Re: cv shaft popped out. doh!!!! (dxtosirex)
http://www.raxles.com
Old Oct 18, 2007 | 02:09 PM
white90crxhf's Avatar
ha, i had a driver side axle from AutoZone pop out on the highway after about 20 miles, *********** wouldnt give me my money back said they'd just replace it. i refuse to go there anymore.
Did you just install 'new' axles?
Old Oct 18, 2007 | 02:12 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default Re: cv shaft popped out. doh!!!! (white90crxhf)
i had this happen to me, everytime it has happened to me was because of a blown differenial, check that, my spider gear bearings were gone so it made my axle get pushed out, do u do alot of burnouts......
Modified by Guiding my way back. at 7:31 PM 10/18/2007
Old Oct 18, 2007 | 02:45 PM
Targa250R's Avatar
be professional
This problem is typically caused by a faulty or missing C-clip on the end of the axle. It could also be caused by some other issue, including bad machining on the inner joint or a differential problem.
Where did you get the axle? Did it have a retaining clip on it? What mounts are you using?
As someone mentioned, make sure to refill the transmission to the proper level when you replace the axle. I've seen too many transmission bearings destroyed by running the trans low on fluid . . .
Old Oct 25, 2007 | 10:02 AM
mycivicswaylow53's Avatar
no answer but it's kinda funny that the cop helped you out... with your loud CRX and all
Old Oct 25, 2007 | 10:10 AM
allmotorB18eg's Avatar
Default Re: cv shaft popped out. doh!!!! (mycivicswaylow53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicswaylow53 &raquo;</TD></TR><TR><TD CLASS="quote">no answer but it's kinda funny that the cop helped you out... with your loud CRX and all </TD></TR></TABLE> that is funny lol
Old Oct 25, 2007 | 04:14 PM
i replaced both cv shafts at the same time. i work at auto zone so i got a good deal on them. i dont remember if it had the c clips on the end or not tho. and no i dont do alot of burnouts. and im using Place Racing motor mounts.
bruce9432
Jul 2, 2012 03:49 PM
Comeback Kid
Sep 19, 2005 07:41 PM
travis
23
Aug 30, 2004 09:08 AM
MisterB
May 9, 2002 03:54 AM
