IAC (idle air control valve) ?
My check engine light is on. The code is 14 which is IAC. I bought a new one from the dealer and replace it. I erase the code with a scanner and next day it came back on. When the check engine light comes on, the car idle up and down. Please help? Its a 96 gsr.
hey how did u check the code of the check engine light??
how did you erase the code after you replaced it??
honestly, i didn't even know u could do that.....
yeah i kno i'm a noob...forgive me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamouskillas »</TD></TR><TR><TD CLASS="quote">hey how did u check the code of the check engine light??
yeah i kno i'm a noob...forgive me</TD></TR></TABLE>
How to check CEL
Did you make sure the coolant doesnt have any air?
Remove the radiator cap and start the engine, try to squeeze the radiator hose and burp the air bubbles out..
Also Under the hood There is a fuse box.. There is a 7.5amp backup fuse..(right next to the ecu fuse) Pull that fuse for 15 seconds.. It will reset your idle..
Most likely you got a defective IACV.. also is the connector plugged in all the way?
How to check CEL
STEINBUCK
Nov 5, 2007 11:16 AM
1998_4dr_gsr
Oct 27, 2006 03:21 PM
Jdmb18EF
Jan 17, 2006 05:34 AM
