Suspension & Brakes Theory, alignment, spring rates....
Prelude OEM top hat orientation..Does it matter?
Old Oct 17, 2007 | 05:45 PM
Halo's Avatar
Default Prelude OEM top hat orientation..Does it matter?
Hey all..I have a 98 Prelude on Koni/GC's..I didn't use the OE dust boot and am running the GC poly top hat over the oem rubber..Problem is the spring is not seating properly at the top, and shredded both the oe rubber and gc supplied poly top mount.
I will be using the dust boot and replacing the OE rubber with only a energy suspension spring isolator per gc instructions. Question is: Do the OEM upper mounts install in a specific orientation? There are 3 bolts situated in a triangular formation i.e below
oneprelude
Dec 13, 2010 08:13 AM
Eks133p3r
Oct 9, 2003 07:40 PM
P-ludE
Apr 9, 2003 10:10 PM
