2 gen CRX badges
Old Jun 20, 2002 | 02:26 PM
sappsycho's Avatar
Default 2 gen CRX badges
Did the 2gen CRX's have the badges on the back if they were HF's?? Also, do any of you know which number (or letter) in the VIN would identify what year the car was made?
I'm a little perplexed. I thought I had a 1990 CRX DX but it says PGM-FI.....when I look at resource.crx.org, none of the 1990's had PGM-FI, but the 88's did and the 91's did....was this just a misprint on the website or what?
Any help would be great, thanks.
Old Jun 20, 2002 | 02:30 PM
spettinger's Avatar
Default Re: 2 gen CRX badges (sappsycho)
do your turn signals screw in from the side? 88-89
is your guage cluster housing boxy? 88-89
try a carfax report on your vin.
Old Jun 20, 2002 | 03:47 PM
thecorey's Avatar
should be easy to tell if its an hf or dx...if it has pgm-fi its not a dx...and if it dosnt have a sunroof...its not an si...problem solved..it has to be an HF
Old Jun 20, 2002 | 03:56 PM
wronghand's Avatar
Default Re: 2 gen CRX badges (wreckedhatch)
The 10th position identifies the year.
J=88
K=89
L=90
M=91
Check out Quickhonda for a complete breakdown of the VIN number.
They are all PGM-FI. It sounds like a DX to me.
[Modified by wronghand, 8:02 PM 6/20/2002]
Old Jun 20, 2002 | 04:14 PM
Hcivic88's Avatar
Default Re: 2 gen CRX badges (wronghand)
Yeah, the DX's were DPFI, and Si's were MPFI - im quite sure, but not positive about this. but you're better off just checking your VIN like wronghand said.
[Modified by Hcivic88, 1:14 AM 6/21/2002]
Old Jun 20, 2002 | 04:29 PM
4wsB21a's Avatar
New User
if it says pgmfi, then you should have a dx. the dx is the only model without a "badge" on the back of it. if you have a black intake manifold that says pgmfi it is a dx. if it says mpfi on an aluminum intake then you have either an hf or si.
Old Jun 20, 2002 | 04:41 PM
wronghand's Avatar
Default Re: 2 gen CRX badges (crxplus)
Actually, I believe that the mpfi manifold has pgm-fi on it as well.
Old Jun 20, 2002 | 05:05 PM
CRXtc 90's Avatar
if it has a passenger mirror its a dx or si. si's have sunroof, carpet on door pannels and engine code is d16, if a hf or dx it will be d15. plus a hf has no clock in the vents
97SS
Nov 20, 2008 10:31 PM
phoenix_iii
33
Apr 25, 2006 05:30 AM
onlyneed4
Sep 2, 2005 07:17 PM
