So what'll break next on my EG?
Old Oct 17, 2007 | 04:40 PM
rentacop's Avatar
Default So what'll break next on my EG?
Ive had my 92 CX since early 2004, and i've taken it from 75k miles to about 110k. So far, i've only had to replace the normal stuff, main relay, timing belt, muffler, brakes. etc. Im trying to plan out or figure out at least whats next to go on my car.
Axles?
Ive also noticed a rattle that goes from 1500-1700rpms, i figured it was the manifold heat shield, so i took it off, but it still rattles. Any ideas?
Old Oct 17, 2007 | 05:03 PM
solsi's Avatar
Default Re: So what'll break next on my EG? (rentacop)
any wheel studs break yet?
Old Oct 17, 2007 | 05:20 PM
MySelfAffliction's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacop &raquo;</TD></TR><TR><TD CLASS="quote">Ive had my 92 CX since early 2004, and i've taken it from 75k miles to about 110k. So far, i've only had to replace the normal stuff, main relay, timing belt, muffler, brakes. etc. Im trying to plan out or figure out at least whats next to go on my car.
Axles?
Ive also noticed a rattle that goes from 1500-1700rpms, i figured it was the manifold heat shield, so i took it off, but it still rattles. Any ideas?</TD></TR></TABLE>
heat shield for the cat? Um your axles "shouldn't" unless the boot tears and releases the grease inside. Other than that i'm not sure what else "usually" goes bad around that mileage since i have never owned one with less than 150k lol.
Old Oct 17, 2007 | 05:22 PM
instrument's Avatar
how are your tie rods?
clutch
water pump etc.
its pretty simple, think of things you havent replaced.
Old Oct 17, 2007 | 05:23 PM
-slow ej-'s Avatar
Default Re: (instrument)
how about , alternator belt, ps belt (if app) ac belt, and all them other belts
*edit, forgot u put timing belt,*
Old Oct 17, 2007 | 05:49 PM
rentacop's Avatar
Default Re: So what'll break next on my EG? (MySelfAffliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MySelfAffliction &raquo;</TD></TR><TR><TD CLASS="quote">
heat shield for the cat? Um your axles "shouldn't" unless the boot tears and releases the grease inside. Other than that i'm not sure what else "usually" goes bad around that mileage since i have never owned one with less than 150k lol. </TD></TR></TABLE>No theres (at least on my car) a 2 piece heatshield surrounding the exhaust manifold.
Replaced water pump. No wheel studs yet, ill look out for that.
Old Oct 17, 2007 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacop &raquo;</TD></TR><TR><TD CLASS="quote">No theres (at least on my car) a 2 piece heatshield surrounding the exhaust manifold.
Replaced water pump. No wheel studs yet, ill look out for that.</TD></TR></TABLE>
There's no heat shield on the cat? Should be unless it has already been taken off.
iluvmyhnda's Avatar
is your rattle sound coming from right around the engine, or the back of it? cause i have a rattle in mine too that i thought was a heat shield, and its at the same rpm as yours.
Old Oct 17, 2007 | 06:06 PM
weavertime1's Avatar
Default Re: (iluvmyhnda)
Sometimes that rattle can be the insides of your resonator or catalyitc converter that has broken up. I have seen that many times at my shop. In that case we usually let it go unless it pisses the customer off to the point where they just can't stand it!!!
Old Oct 17, 2007 | 06:43 PM
zach246's Avatar
lol
Old Oct 18, 2007 | 09:04 AM
rentacop's Avatar
Hard to tell where exactly, it only happens under load so i can't reproduce it when under the hood opening the throttle.
Old Oct 18, 2007 | 09:10 AM
p nut's Avatar
I would look into the cooling system. Check the radiator. Honda radiators tend to develop leaks around 90k. Replace the hoses, too. Like others have said, axles shouldn't need attention, unless you see the boot torn. If you do need new axles, get ones from Autozone, NAPA, etc. where they offer lifetime warranties on them.
her92eg
Mar 24, 2014 05:46 AM
cottonfamily05
Sep 19, 2005 01:21 AM
typeturbosh
Jul 5, 2004 08:05 PM
kikiboi
Nov 12, 2002 06:21 PM
