swapping needles
Old Oct 17, 2007 | 03:39 PM
ghosthatch's Avatar
Default swapping needles
why cant you do this in an eg?
Old Oct 17, 2007 | 04:00 PM
Redbone's Avatar
because it will give you AIDS! Oh wait, are talking about gauge needles? More info please.
Old Oct 17, 2007 | 04:13 PM
mikeycivic's Avatar
Default Re: (Redbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redbone &raquo;</TD></TR><TR><TD CLASS="quote">because it will give you AIDS! Oh wait, are talking about gauge needles? More info please.</TD></TR></TABLE>
I peed a little when I read ^^^ LOL
Old Oct 17, 2007 | 04:39 PM
ghosthatch's Avatar
Default Re: swapping needles (ghosthatch)
i want glowing needles so bad
i snagged some off an integra at a junkyard just in case there was a way, haha
Old Oct 17, 2007 | 04:44 PM
BlueIntegraBoy's Avatar
Buy a JDM SiR EG6 cluster...
Old Oct 17, 2007 | 04:49 PM
ghosthatch's Avatar
Default Re: swapping needles (BlueIntegraBoy)
i dont know km
Old Oct 17, 2007 | 04:54 PM
It's easy for a quick, estimated conversion...
Drop the 0 after each KMH reading and multiply the first number(s) by 6.
For example: 60 KMH = 36 MPH, 100 KMH = 60 MPH, 180 KMH = 108 MPH.
Old Oct 17, 2007 | 05:22 PM
ghosthatch's Avatar
id much rather not have white faced gauges neither
Old Oct 17, 2007 | 05:26 PM
-slow ej-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghosthatch &raquo;</TD></TR><TR><TD CLASS="quote">id much rather not have white faced gauges neither</TD></TR></TABLE>
agreed, my car came wit it, and not its like stuck on the cluster , i think prev owner super glued it on the oem cluster, now i got a jaydem white face cluster with usdm mph readings
Old Oct 17, 2007 | 05:32 PM
Get an EG4 or EG5 gauge cluster.
EG4 cluster shown...
Old Oct 17, 2007 | 05:39 PM
ghosthatch's Avatar
how many hundreds of dollars will that cost me? someone should just find a way to swap needles hahahaha
Old Oct 17, 2007 | 05:41 PM
Default Re: (ghosthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghosthatch &raquo;</TD></TR><TR><TD CLASS="quote">how many hundreds of dollars will that cost me? someone should just find a way to swap needles hahahaha</TD></TR></TABLE>
They are worth no more than the EG6 clusters. You can probably find them for around $100.
Swapping needles isn't a good idea. I have already broken a tachometer doing that.
Old Oct 17, 2007 | 05:46 PM
Johnny Ricer's Avatar
Default Re: swapping needles (-slow ej-)
k=kmph r=mph
k=1.61r
There is your simple algbraic expression to convert MPH to KMPH so reverse it and you can figure out your speed..
Old Oct 17, 2007 | 05:59 PM
23-10's Avatar
Default Re: (BlueIntegraBoy)
Or try to get a UK VTi (almost the same as SIR) They use miles there too.
If you try to remove the needles you wont beable to put them back in.
The stems that hold them on snap.
Old Oct 17, 2007 | 06:32 PM
polything's Avatar
the needles are hard to pull out
Old Oct 17, 2007 | 08:38 PM
ghosthatch's Avatar
the integra needles popped out pretty easily, i kinda worked with them tho making sure not to break them. i wish i had an eg cluster to mess with
Old Oct 17, 2007 | 08:49 PM
ghosthatch's Avatar
id rather not use em, but if i can find a cluster that would match up to mph gauge faces, i have a set of black ones. id need it to be at 180 at the center
Old Oct 17, 2007 | 09:36 PM
TANGO28's Avatar
let me know how it went, cus when i tred takin my rpm needle out and put it back in it doesnt seem to work anymore,is there any correct way to put it back in?
Old Oct 17, 2007 | 10:12 PM
OversteerMotorSports's Avatar
Default Re: (TANGO28)
I have swapped needles before without any troubles. When putting the new one on it almost felt as if there was only one way it went on and it slipped right into place. Maybe I just got lucky.
Hope for the best and go for it.
Old Oct 18, 2007 | 07:57 AM
ghosthatch's Avatar
what needles did you use?
Old Oct 18, 2007 | 11:19 AM
I honestly couldnt tell you. It was for a friend and I didnt ever ask. He might remember, maybe ill bring it up in a convo and figure out what needles.
Old Oct 18, 2007 | 12:24 PM
crazyjetsfan22's Avatar
Default Re: (OversteerMotorSports)
be careful taking off the needles. i broke one on a cluster i was ******* around with. if i can get my hands on some integra needles ill give it a shot.
Old Oct 18, 2007 | 07:55 PM
ghosthatch's Avatar
Default Re: (crazyjetsfan22)
i have the red/clear needles from a teg
Old Oct 19, 2007 | 10:22 AM
ghosthatch's Avatar
looks like i have to find a new cluster to try it out on.... the only cluster that would work to put gauge faces over and convert to mph would look to be the spoon one and im def not trying to spend all that on a damn cluster!
igo4bmx
278
Feb 25, 2019 01:08 PM
cxSHOE
Mar 20, 2007 06:34 PM
joethejoeman
Dec 30, 2006 11:36 PM
n1div
Oct 5, 2004 12:28 PM
lowezz
Mar 25, 2004 06:26 PM
