Are these tires still ok to drive on?
Old Oct 17, 2007 | 11:45 AM
lando griffin's Avatar
Default Are these tires still ok to drive on?
not sure what caused this but I just picked these up and wondering if they are still ok to drive on.
click the picture for full size
Old Oct 17, 2007 | 12:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Are these tires still ok to drive on? (lando griffin)
Well, you've got some significant chunking going on there. My guess is that these tires were used in a track event or autocross, where they got very hot.
How old are they? (Click here to learn how to tell.) If they're not too old, I would use 'em, no problem...
Old Oct 17, 2007 | 12:29 PM
Default Re: Are these tires still ok to drive on? (nsxtasy)
is this it?
Old Oct 17, 2007 | 02:22 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lando griffin &raquo;</TD></TR><TR><TD CLASS="quote">is this it?</TD></TR></TABLE>
Probably not. It's usually molded into an area in the sidewall that's depressed to make it easy for them to change the serial numbers, not numbers that stand out away from the sidewall. And the numbers are usually slightly bigger than that.
It might be on only one sidewall, not both.
Old Oct 17, 2007 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Humm this is the other #'s besides the tire size and air pressure
Old Oct 17, 2007 | 04:22 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lando griffin &raquo;</TD></TR><TR><TD CLASS="quote">Humm this is the other #'s besides the tire size and air pressure</TD></TR></TABLE>
Yup, those are the numbers. The tires were made in 2005. Go ahead and use them, they should be fine.
Old Oct 17, 2007 | 04:50 PM
Awesome thanks! I dunno if you can really tell from picture but, how much life do you think is left on them?
Old Oct 17, 2007 | 05:06 PM
H22Ej1's Avatar
Shenanigans
you can tell from the dot number, where it says DOT xxxx xxxx xxxx the last 4 numbers is the week and the year the tire was made so 2505 would be about halfway into 2005
edit: as for your tires the cracking seems pretty rough but ive seen much worse id say they are ok there seems to be decent tread left just keep an eye on possible camber wear near the cracking
Old Oct 17, 2007 | 07:35 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lando griffin &raquo;</TD></TR><TR><TD CLASS="quote">I dunno if you can really tell from picture but, how much life do you think is left on them?</TD></TR></TABLE>
You can't tell from a picture, and tread life varies.
Old Oct 18, 2007 | 02:12 AM
songoku's Avatar
dunno,but if i were u i was gonna bye new ones
Old Oct 18, 2007 | 04:58 AM
MIKE@R90's Avatar
I wouldnt be ridin on those Tires at all, Its the safe-factor when it comes down to this, even if there "newer".
Old Oct 18, 2007 | 06:33 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (MIKE@R90)
I don't think there's anything unsafe with these tires.
CardDealer
Feb 28, 2006 03:14 PM
Bbasso
Mar 29, 2005 09:32 AM
kch22t
Nov 13, 2004 10:02 PM
JDMBB2
Mar 12, 2004 11:34 PM
Shawn01
Feb 4, 2003 02:16 PM
