valve adjustment specs info needed blah =P
Guest
Posts: n/a
heres whats happening:
d15b1 block stock rods and pistons
d16a6 ported, polished and milled head to give me 12:1 compression
with that compression via the milled head, do the valve adjustment specs change over stock? or it is still the same adjustment specs for the d16a6 head? basicly i dont want my valves to be smashing into my pistons once the head is swaped on.
91, adjustment, adjustments, clearnce, crx, d15b1, d16a6, head, honda, milled, settings, specifications, stock, valve, vave
