Need a little timing info
Old Jun 20, 2002 | 12:54 PM
SOUTHCREX's Avatar
Default Need a little timing info
I just put a pre obd z6 in a crx, every thing is running good except for the timing, if know about a pre obd z6 you know that only two of the bolt holes line up. Well from where its bolted i have to turn my distributer about a 1/4 turn clockwise and the timing smooths out perfect. What way would i have to move the cam gear so that i could get the distributer back in line with the and the timing pretty close. clock wise or counter?Thanks for your help
Old Jun 20, 2002 | 01:00 PM
Urban Business
Guest
Posts: n/a
Default Re: Need a little timing info (TEAM GARAGE SHIFTDOWN)
cam gear is cam timing, dizzy turning is ignition timing
Old Jun 20, 2002 | 01:53 PM
SOUTHCREX's Avatar
Default Re: Need a little timing info (TorteX)
OK,then if i have to turn my dist about an inch clockwise past the bolt hole to get iming right then what do i do so that i can get the dist lined back up and also have good timing? Thanks, it the holes dont line up?
Old Jun 20, 2002 | 02:37 PM
Urban Business
Guest
Posts: n/a
if thats the case your prolly a tooth off tdc w/ your timing belt
Old Jun 20, 2002 | 06:39 PM
SOUTHCREX's Avatar
I tried to move it one tooth one way and one the other way, and it really didint help. could the rotor cap be on the oposite way?dose it treah on both sides or the hole
titosek4
Jul 25, 2009 04:58 PM
Salsa
Feb 28, 2009 11:31 AM
mini-v-si
Jun 29, 2004 04:54 PM
clovers
May 7, 2004 03:31 PM
