CEL stays on and car wont run sometimes, AHHHH im frustrated.
OK, so i started with a 94 ls automatic. Now about 6 months ago i was doing some tuning and (burning chips tryin to get the antilag to work)) so the ecu was laying in the floor and all of the sudden the car sarted this thing where the CEL would come on and stay on. It has a walbro 255 in it so you can hear the pump prime, but it usualy goes for 3-4 seconds, and when this happens it primes for maybe a full second. Then it didnt do it for like 5 months, and then the other day, it did it again. I tried for an hour and got frustrated and left. Came back without touching anything and it was fine. And it did the same thing tonight. Except i was driving and the CEL came on and the car dies. Is it a Main relay? Ive checked all the fuses and their fine And i converted the car to manual. Any input? PLEASE HELP!!!!!
Oh and when i go to check the code, the cel still just stays on solid. this has been with several different ecu's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">Oh and when i go to check the code, the cel still just stays on solid. this has been with several different ecu's</TD></TR></TABLE>Your ECU is ****. Swap it with a known good one and try again. Oh wait, on second thought, maybe the chip your putting in there is ******* **** up. What are you running and what have you been putting in there?
Its not the chip or the ecu. ive tried a chipped P06, P28, P75, P72. all do it. And it will just happen all of the sudden. On several different chips. Its gotta be a wiring problem or relay or something like that.
