!!!!>>>> Help 88 CRX Si ECU Showing A Code 4 <<<<!!!!
Hey there fellow Honda-Tech friends! I have yet another problem with my Rex. I finally finished installing my new dizzy when i took it to school. On the way back home i was driving and my car suddenly lost power and my check engine light came on. I checked the ECU and it was showing a Code 4, Which means Crank Angle Sensor. My car will turn on and sound normal for about 3 seconds and then the RPM's will suddenly drop to about 500 or lower and it will sound like it is camming. If i try and give it gas it will just want to die. How can i fix this? Thanks again Honda-Tech!!
Modified by i_VTEC at 8:59 PM 10/16/2007
Inside the distributor. If you take the cap,ignitor,and coil off, you will see teeth on the dizzy shaft. The sensor counts the teeth on the shaft. Is it plugged in good?
Ill have to check that in the morning. It's raining outside. But if so then what else is it? Defective dizzy maybe?
Ill double check it and if so ill probably just get another one tomorrow or something, But is there anything i can do to fix this one?
The-obd0-one
Nov 12, 2010 04:34 PM
Silent Knight
Jun 28, 2005 06:29 AM
