inside tire wear with 17's
is that something thats common with 17's on a honda? I had alot of camber wear with 17's. I'm in the process of lowering the car and putting it on 14s but im wondering if hte camber will get even worst or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">You need a full alignment: camber, caster, and toe.</TD></TR></TABLE>
Only toe is adjustable on the stock suspension.
Depending upon how low the car is, having the toe adjusted properly can alleviate much of the tire wear.
Most shops, under liability, will not touch a car with lowered (modified) suspension, even if your asking for only a toe alignment. I had to go to about 7 places before someone said yes.
Coopa B18c5
Jan 18, 2013 07:58 PM
xXx Justin xXx
12
Feb 12, 2004 07:51 PM
