Car dies???
Old Oct 16, 2007 | 11:56 AM
91-ef-hatch's Avatar
Default Car dies???
Whats up guys. I have a 1.5 DPFI
Sometimes when im driving it just shuts off. I have a full tank of gas, no loose connections, or anything like that.
The car wont start unless i turn the key all the way off and then back on and it will start with no probs.
Maybe a bad pump or something. Im lost as of right now
Old Oct 16, 2007 | 09:01 PM
1 Fly SI's Avatar
Default Re: Car dies??? (91-ef-hatch)
pump,ignition switch,main relay?
Old Oct 17, 2007 | 12:47 PM
driftingindiego's Avatar
are you getting any cel's?
what he said is what id check, i would also check your fuel filter, when was the last time it was replaced?
Old Oct 17, 2007 | 12:50 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91-ef-hatch &raquo;</TD></TR><TR><TD CLASS="quote">Whats up guys. I have a 1.5 DPFI
Does it crank on the first shot? Sounds like you have to prime it 2 times for it to get fuel. Whats the fuel pressure read when key is turned once?? What the pressure when key is turned twice??
Could be fuel pump but have to check it first
Old Oct 17, 2007 | 04:46 PM
Default Re: Car dies??? (alscrx)
Dont know what the feul pressure is.. It will start the first time no probs.
I guess ill have to buy a cheap fp guage. But yea i have to prime it before it will start. And when it does start itll go about 10 feet and shut off again. About three or four times later it will run fine.
Im thinking that it could be the pump, but it wouldnt keep running.... or maybe the fuel filter is clogged??????
Ive been trying everything to not pull the pump but nothing is working so far....
ttcheung97
Aug 24, 2020 06:31 AM
PinkMaggit
Aug 16, 2008 08:49 AM
z crx z vtec z
Jun 15, 2007 07:41 PM
JoeCDN
15
Jul 13, 2004 06:36 AM
garagespecial
Jun 25, 2002 10:00 AM
