Who could tell me how much weight a stock DC5-R stock wheel ?
Old Oct 16, 2007 | 11:19 AM
yellowturbo's Avatar
Default Who could tell me how much weight a stock DC5-R stock wheel ?
Just like my topic says... im searching for the stock weight of an DC5-R from Japan. I really like those wheels and the OEM look but I need to know if they are much heavier than an aftermarket good quality wheel.
If someone know the width of the wheel it would be nice to let me know too !
Old Oct 16, 2007 | 02:59 PM
concept11253's Avatar
Pretty sure they weigh around 17ish lbs. I believe they are 17x7's.
Old Oct 16, 2007 | 04:01 PM
Aco512's Avatar
i always thought they were a similar weight to the 05-06 type-s wheels
Old Oct 16, 2007 | 04:26 PM
Todd00's Avatar
I said I don't want a title!
Default Re: (Aco512)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aco512 &raquo;</TD></TR><TR><TD CLASS="quote">i always thought they were a similar weight to the 05-06 type-s wheels</TD></TR></TABLE>
They are. They are about 20-21 lbs IIRC. Definitely not a light wheel.
Note to the OP: these are not a direct bolt-on. You need parts to make them work.
Old Oct 16, 2007 | 05:16 PM
Aco512's Avatar
yeah, spacers are needed i believe
not worth it unless you just want the look of it
Old Oct 16, 2007 | 10:21 PM
mikestypes's Avatar
Default Re: (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
Note to the OP: these are not a direct bolt-on. You need parts to make them work.</TD></TR></TABLE>
You don't have to get a spacer for them to bolt on, it just looks better. The difference in offset is 7mm I believe, so they would be 7mm into the wheel well more than a stock wheel. They still bolt on fine.
Aside from that, they are not light at all and are only a good choice if you are trying to replicate a TypeR. Get lighter aftermarket wheels for less, IMO.
Old Oct 17, 2007 | 04:16 AM
thanks !
I really like the look of them but if the are that much heavier compare to a good wheel I prefer to save some weight.
Old Oct 17, 2007 | 06:52 AM
Todd00's Avatar
Default Re: (mikestypes)
The offset of the DC5R wheel is +60. Couple that with a 7" wide wheel, and that's definitely going to rub.
People run 15mm spacers to correct for this on the USDM cars. That's pretty significant.
Old Oct 17, 2007 | 08:19 AM
mikestypes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">The offset of the DC5R wheel is +60. Couple that with a 7" wide wheel, and that's definitely going to rub.
People run 15mm spacers to correct for this on the USDM cars. That's pretty significant.</TD></TR></TABLE>
Ah yes, it was more than 7mm. However, they do not rub on a local car here with out spacers.
Old Oct 17, 2007 | 09:21 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypes &raquo;</TD></TR><TR><TD CLASS="quote">
Ah yes, it was more than 7mm. However, they do not rub on a local car here with out spacers.</TD></TR></TABLE>
Maybe with a narrow 205/45/17 that wheel will be fine, but put some 225/45/17's on it and it'll be all over your inner fenders on both the back and front. Even moreso if lowered.
Old Oct 17, 2007 | 04:05 PM
DC5RK20A's Avatar
8.8kg or 19.36lbs.
Old Oct 17, 2007 | 04:37 PM
mikestypes's Avatar
Maybe with a narrow 205/45/17 that wheel will be fine, but put some 225/45/17's on it and it'll be all over your inner fenders on both the back and front. Even moreso if lowered.</TD></TR></TABLE>
Nope, even has that size tire, no rubbing.
Also, I run an 18x8 with a +48 offset and it does not rub either. The extra half inch (12.75mm) width would put the inner rim lip in the exact same location as a 7" with 60mm offset.
PURP
Honda CR-V & Element
Apr 18, 2017 10:25 PM
crxman1983
Oct 14, 2007 03:05 AM
eyesolation
Jul 16, 2004 11:26 AM
Mr.Death
Jun 6, 2004 04:14 AM
ViZ
Jan 3, 2004 08:47 PM
