part number for integra tie rods?
http://www.acuraoemparts.com/delray/jsp/home.jsp
look up and buy parts here for your acura.
outer tie rods are more oftenly changed. theyre a lot easier too. but it always depends on what really needs to be changed. check for play by shaking the suspension and feeling for play and isolate the source. any play is bad.
if a boot is torn, then its a sure sign of needing to be replaced.
Modified by Tyson at 12:50 PM 10/16/2007
Do you happen to know the exact part number? I search and it comes up but I'm not even sure if I'd be buying the correct item. and also if there are washers, boots, and such that I should get along with it.
What about these?
http://cgi.ebay.com/ebaymotors...idget
I know they're not oem but I believe PatrickGSR used ebay upper control arms from seller Arm Can and said they are of very good quality. Thoughts?
What about these?
oh tyson, i did do it on my own. however, the descriptions of the parts aren't too good and there is no illustration of what part it is. (when i do a search)
http://www.acuraoemparts.com/d...=Part
Here is the search I got. Now, from there I don't know exactly which parts are necessary to replace/purchase. Thanks for helping
I'm going to be putting in new coilovers so I wanted to replace tie rods and upper arms while i'm at it. even if they didnt necessarily need replacing immediately.
mingbling96
Dec 11, 2004 04:07 PM
