PowderCoating Stainless Steel
Old Oct 16, 2007 | 10:51 AM
94WhtTeg's Avatar
Default PowderCoating Stainless Steel
Hi,
I bought an X-Bar and it's Brushed Stainless Steel (304).
Is it possible to PowderCoat it and it not turn to crap?
I read it's possible, but risky, only thing I could find...
So has anyone here had any luck Powdercoating Stainless?
Thanks!
Old Oct 16, 2007 | 11:16 AM
stoned_sol's Avatar
Default Re: PowderCoating Stainless Steel (94WhtTeg)
we have a couple parts here at work that require a powdercoat over stainless steel. we don't have issues with the appearance of the powdercoat but the adhesion of the powder to the metal. we have found a coarce grit grain or orbital finish helps give the powder something to hold to. with the Xbar being an interior piece i don't see any real issue with powdercoating this. if this was an under chassis or suspension component i wouldn't recommend it.
Old Oct 16, 2007 | 11:29 AM
94WhtTeg's Avatar
Default Re: PowderCoating Stainless Steel (stoned_sol)
I was figuring the problem would be the adhesion as well, true it is an interior piece, but I didn't want to waste the money powdercoating it, if it was just going to peel off heh.
Old Oct 16, 2007 | 12:55 PM
Sleepy86o's Avatar
You can powdercoat any metal that can withstand 380 degrees because that is the temperature the powder cures at. Lead for instance will melt, same with solder.
Old Mar 4, 2008 | 10:44 PM
powderedcivic's Avatar
brushed stainless is great for coating! and i know some guys that would coat it for a fair price hit them up if you still need it done.
gsspowdercoating.com
RO_SUNNY
Welding / Fabrication
49
May 15, 2015 06:24 AM
b16bri
Oct 11, 2011 04:28 PM
QuangAlang
Feb 15, 2008 04:34 PM
hondakevin21
Jan 8, 2007 01:11 PM
RTW DC2R
Apr 25, 2006 03:28 PM
